POWER STEERING CONTROL VALVE QUESTION
Posted By HazardTBird Last Year
HazardTBird
Question Posted Last Year
Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)
Last Active: 7 Months Ago
Posts: 50, Visits: 1.3K
I have never understood what Ford means in the manual when they describe how to adjust the centering spring on the power steering control valve. The 57 Manual says "tighten securely" and memory tells me that the description is similar in the 55 & 56 manuals. Does "tighten securely" mean to compress the spring fully to a point that you are getting firm resistance like an ordinary (without a spring) nut or does it mean to just make contact with the spring and then back it off a quarter turn? Without having it apart I can't remember if the rod is threaded far enough down to allow it to tighten all the way to fully compress the spring. A picture is attached below. Any thoughts would be appreciated.
http://forums.y-blocksforever.com/uploads/images/6b65abe6-f874-418f-88a8-320f.jpg
Last Active: Today @ 12:34:28 AM
Posts: 1.8K, Visits: 306.3K
It is instructing you to run the nut down until it stops. No need for HARRY ARMSTRONG.
You then loosen until you get the clearance called for if the ball stud is in good condition.
When adjusted correctly, the system is manual steering straight ahead and once it hits either seat (3320), it initiates PS.
HazardTBird
Kultulz:
Thanks for the response. Sounds like no way to adjust the centering spring with the control valve on the car; off she comes.
Also check the ball stud for wear. There are repair kits available.
http://forums.y-blocksforever.com/uploads/images/9d7eae34-dd4d-438f-92b9-673f.jpg
http://forums.y-blocksforever.com/uploads/images/f5a46814-c260-459e-a1be-1a5b.png
