Last Active: 8 days ago
Visits: 32.6K
How about a 390 CFM Holley 8007-0. I have had a couple on my 56 292 and my friends 56 with 292. They come new with 51 main Jets but other than replacing them with 56-60 Jets no other Mods needed. I replaced Needle and Seats with all Steel Units meant for Alcohol Engines so no problem with sticking Inlet Needle. Never had any problem with them.
Visits: 22.6K
The Summit carb is a better carb for these vintage vehicles which sit several days to several weeks at a time because it is a bowl style carb instead of the sandwich metering blocks of the 4150/4160 Holley style carbs. If you can install the air filter assembly on the Summit, I would recommend it. I have the 750VS on my Thunderbird, and I can let it sit for a month and it will still start in the south TX heat. Joe-JDC
Visits: 1.5K
Anyone have knowledge of a Edelbrock 1403? I found one at a decent price. New. 500 cfm 4 bbl
