Transmission dust cover gasket
Posted By B-rad 2 Years Ago
B-rad
Posted 2 Years Ago
Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)
Last Active: 3 Weeks Ago
Posts: 362, Visits: 1.5K
Is there a gasket gor the cover for the flywheel? I'm assuming that piece is the dust cover.
Brad
Sierra Vista Arizona
1954 Lincoln Capri
cokefirst
Posted 2 Years Ago
Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)
Posts: 168, Visits: 2.4K
If you are talking about the crescent shaped sheet metal piece that covers the lower section of the bell housing, there is no gasket.
B-rad
Posted 2 Years Ago
Isn't there fluid inside the tranny at that place?
Brad
1954 Lincoln Capri
alanfreeman
Posted 2 Years Ago
Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)
Last Active: 4 hours ago
Posts: 385, Visits: 6.2K
The fluid is inside the transmission and the torque converter and not around the flywheel.
Posted 2 Years Ago
Last Active: 5 hours ago
Posts: 2.0K, Visits: 306.6K
http://forums.y-blocksforever.com/uploads/images/d3755479-de06-465d-9d83-a897.png
Yes, there is a seal - BASIC PART NUMBER 6411
The fluid is contained within the TORUS ASSY. The TORUS ASSY bolts to the flywheel.
There are two paper gaskets -
1) TORUS COVER to FLYWHEEL - BPN 7945
2) FLYWHEEL TO CS FLANGE - BPN 6377 (You indicated that you don't think you need that one)
NOTE - There is also a starter motor to bell gasket - BPN 6436
B-rad
Posted 2 Years Ago
Great thanks. It looks like it's just on the kne side, straight.
Brad
1954 Lincoln Capri
B-rad
Posted 2 Years Ago
Am I correct in assuming that the gasket I need is just on the rear side of the cover?
Brad
1954 Lincoln Capri
Posted 2 Years Ago
The seal itself attaches to the front of the duct cover. All it does is keep road dirt and splash form entering the bell.
http://forums.y-blocksforever.com/uploads/images/27763662-3d1b-4e10-87e4-2129.png
