Between flywheel and crank
Posted By B-rad 2 Years Ago
B-rad
Posted 2 Years Ago
Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)
Posts: 362, Visits: 1.5K
Is there anything between the flywheel and crank or us it just metal to metal? I know there's a gasket between the flywheel and tranny
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 2 Years Ago
Posts: 2.0K, Visits: 306.7K
http://forums.y-blocksforever.com/uploads/images/5303f014-f845-4d41-9007-7ce5.png
http://forums.y-blocksforever.com/uploads/images/21f43c7b-b71c-4617-8fd5-3fe5.png
EAD 6377-A GASKET - POSSIBLY - https://www.charlietranny.com/Hydramatic.htm
B-rad
Posted 2 Years Ago
Thanks. I took the flywheel off the motor 18 months ago and don't remember a gasket between the two. Do you know if it's cork? I bought a engine gasket set and wonder if it's in there. Or I could make one. It says that there are washers on the bolts to the crank. I put all the hardware in a baggie and labeled it. There were just bolts in it, no washers
Brad
1954 Lincoln Capri
Posted 2 Years Ago
Check the PARTS LIST again. Lock washers only on cover to flywheel.
As for the gasket, check with the URL I posted.
B-rad
Posted 2 Years Ago
I see my error on washers. Does anyone know if the flywheel to crank gasket can be made from cork? I have some and they want over $30 for the gasket with shipping. I'd rather make one for basically free. Does thickness matter?
Brad
1954 Lincoln Capri
B-rad
Posted 2 Years Ago
I see that there is something numbered 2377 on the diagram but I don't know what it is. Charlie from your link doesn't know either. Trying to confirm what exactly it is
Brad
1954 Lincoln Capri
Posted 2 Years Ago
I see 6377,which is the gasket being discussed, but no 2377 ...
B-rad
Posted 2 Years Ago
Typo. 6377. Charlie doesn't seem to have that and doesn't know what it's supposed to be. I contacted him. No luck on internet search for part number either.
Brad
1954 Lincoln Capri
Joe-JDC
Posted 2 Years Ago
Posts: 798, Visits: 23.3K
Crankshaft to flywheel/flexplate does not have anything between them.  If it did, there would be a vibration/wobble as it deformed with age.  Joe-JDC
B-rad
Posted 2 Years Ago
Thx Joe. Looking at the diagram above, it does show, to the far left, 6377-A which is labled as a gasket on the parts list under the diagram. I do not remember taking anything off when I took the flywheel off but the engine went to the rebuilder after so if there was a gasket stuck to the end of the crank I wouldn't have known. I do have a call into him to see what he knows. If that part wasn't on the diagram I would feel better putting it together without anything in between. Your case definitely holds merit about the wobble.
Brad
1954 Lincoln Capri
