Posts: 1.4K,
Visits: 2.0K
It's very common to convert 6v to 12v; Ford did it in 56. Why? Cars were being equipped with more power accessories, and higher-compression engines required more cranking power. Whether you have 6v, 8v, or 12v, all of the components should be in good condition.
Visits: 8.5K
Just an update .. decided to abandon my idea of controlling all the voltage at the input .. Just adjusted the regulator down to 8.5 from 9.5 , seems easier on bulbs with no issues Thanks for all your opinions and coments . I'll let you know if anything arises Fred
Last Active: 4 hours ago
Visits: 498.2K
You may find out that the 8.5 will not keep your battery fully charged. Normal 6 volt systems usually require around 7 or so volts and 12 volt systems around 13.5- 14.2 volts to keep the battery fully charged. fast freddy (6/24/2024)
Visits: 8.5K
I'll keep an eye on the battery state thanks Fred
