By fast freddy - 2 Years Ago
Hi guys , I know I'll get blasted for going to an 8 volt battery, but hey it starts like a brand new car.. I was worried about the 6 volt radio ( bone stock 55 country sedan ) so I wired in a 15 amp capacity buck converter and adjusted the output down to 6.2 volts to the radio , seems to work as expected. But the i got thinking (dangerous ) why cant I wire it into the yellow wire at the solenoid since it seems to be the main if not only power feed off the battery , effectively controlling the feed to everything to 6.2 volts ? I'd be interested in your thoughts... Thanks Fred
By 55blacktie - 2 Years Ago
If everything is working as it should be, and you're happy, why change it?
It is working great but first day out it blew a bulb and I can only expect more
I hadn't thought of that, but I did swap out all of my bulbs to 12v when converting to 12v. It's not a fun job on a 55 Tbird/w dash in place, even with the seat and steering column removed (I'm claustrophobic).
By miker - 2 Years Ago
The heater motor will probably be ok, and I don’t think the King Seely gauges are real voltage sensitive. But I don’t know that. The bulbs will have a shorter life, but having never tried that 8 volt solution I don’t really know. You might go check the voltage at the headlights, fast idle to get a charge and lights on. The old wiring might just have enough voltage drop from age and connections that they’re still ok. Likewise the tail/brake lights.
What did you set the charging voltage to? I’ve mainly seen 8 volt batteries used on old tractors, and there’s not a lot of electrical on an old tractor.
It’s a band-aid at best but I’m sure you’re aware of that. I worked for a Sears Auto center in the 60’s and it was common to install 8 volt batteries in bigger GM cars. I’ve run 12 volt tail/stop bulbs on 6 Volt Harley Davidsons. For interior lights you can turn your dimmer rheostat down just a little but it will cause a little extra heat. Good luck.
By paul2748 - 2 Years Ago
As others mentioned, your putting a band aid on whatever problem you have (and you acknowledged it). Fix what's wrong - connections, wire sizes, etc.
I set the regulator at 9.5 volts... my concern is that I blew the lt rear turn bulb , first time out
went over connections and put some new (large) cables on and it was better but I wanted better still
By alanfreeman - 2 Years Ago
I agree with Paul. I have four '54's and they are all 6 volt. One has all new wiring harnesses and power windows and seat and the windows roll up and down on 6 volts faster than my modern cars. They all crank and start quickly because the wiring is good. If you are keeping your car original then fix your problem.
It's very common to convert 6v to 12v; Ford did it in 56. Why? Cars were being equipped with more power accessories, and higher-compression engines required more cranking power. Whether you have 6v, 8v, or 12v, all of the components should be in good condition.
Just an update .. decided to abandon my idea of controlling all the voltage at the input .. Just adjusted the regulator down to 8.5 from 9.5 , seems easier on bulbs with no issues Thanks for all your opinions and coments . I'll let you know if anything arises Fred
You may find out that the 8.5 will not keep your battery fully charged. Normal 6 volt systems usually require around 7 or so volts and 12 volt systems around 13.5- 14.2 volts to keep the battery fully charged.
fast freddy (6/24/2024)
I'll keep an eye on the battery state thanks Fred
