1955 Ford Customline Power Steering Hose Query.
Posted By Phil Gillespie Last Year
Phil Gillespie
Last Active: 6 Months Ago
Posts: 15, Visits: 562
Have a leak at the small steel bend on the Fluid Pressure line to control valve. Trying to locate a replacement hose here in NZ impossible task!!
The pressure line has a join connection in the pipe does the contain sme sort of restrictor, N/R valve?? To get a hose made at a hose doctor need some info on this hose. Its the portion that does connect to control valve not at the pump end.
Appreciate advice on this one.
Thanks Phil NZ
Posts: 1.9K, Visits: 194.9K
Phil, since you’re not getting anything here, try over on the Ford Barn. There’s been a number of p/s discussions lately, and maybe more members in AU and NZ who might be of help. Or at least on the right side of the date line.
Phil Gillespie
So had a new high pressure hose made up as fitted one was leaking from bend setion. Old hose cut up and this section with the crimped area in central area did indeed show an orifice fitted here. 1/4" in size. Now I know.
Phil NZ
