Visits: 1.8K
Thanks, Charlie.
Visits: 1.8K
Charlie, can you post a photo? How about part no. & source? Thanks.
I've been using baffled grommets. They work great.
Visits: 1.8K
I bought an Ace valley cover during the pandemic. Initially, I couldn't contact them because everything in NZ had shut down. Once I made contact, everything went well. I think it was "Randy" who was very helpful. The currency exchange rate is in our favor, the valley cover arrived ahead of schedule, no duty fees, and I'm happy with the quality. A pcv grommet was included, but no baffle on the underside. Randy said that they don't include a baffle due to varying lengths of pcv valves. According to Ted, it's not necessary for the baffle to completely enclose the pcv valve; the sides can remain open. However, you do want the baffle to deflect oil away from directly splashing onto the pcv valve.
How's my memory, Ted?
Posts: 1.9K,
Visits: 194.9K
You’ll like them on the engine even better. They go on just fine. For those who haven’t seen them. Mine painted to match.
Visits: 3.4K
Thanks to all you fellows who replied to my question, they are all very helpful, and give me a good idea of what I wanted to know. I will be installing a set of Ace custom Mercury script valve covers in a week or 2. I have had them for about 3 years, and am going to swap out my old Offenhauser covers for the ace custom ones, and don't want to mess them up . Thanks again to everyone.--- JIm
Visits: 2.4K
I snagged mine from YBloke in Australia... Ultimately he told me to get them down to 5-6 lb/ft...here is my HAMB Thread asking all about it. https://www.jalopyjournal.com/forum/threads/y-block-valve-cover-leaks.1297221/#post-14929287This is for cast aluminum.
Visits: 1.8K
If using a torque wrench, it might be safer to use inch lbs; don't over-tighten, or they'll leak.
Posts: 7.5K,
Visits: 205.8K
The torque specs in the ’57 Shop Manual (page 1-84) calls for 2-2½ ft/lbs. The manual does not specify steel or aluminum but would assume that’s the steel cover specification.
