Visits: 22.2K
under just when you think you seen it all.working on a 55 272 and putting on the rear seal holder using the side rubber and nail i noticed how easy the sideseals went in their usually a pain to get down.the nail went in like nothing.i knew something was wrong.it would have leaked like a sieve.got another holder from a newer engine perfect.the 55 holder was to narrow.it still had its original rope and side seals.is this common with the early engines and i just never seen it before.
Last Active: 4 days ago
Posts: 7.5K,
Visits: 205.8K
I personally have not run across a rear seal retainer that had the side grooves not tight enough for the vertical side seals. And I’ve dealt with all years, and they all fit the same.
Visits: 22.2K
i just measured it.i was thinking maybe .025 but it was .045 narrower.this is a55 272 CEBY ENGINE so a canadian engine.i had these blocks before but never run into this.but i have so many parts laying around i may have used a newer one.
