Visits: 206.1K
Last Active: 2 Weeks Ago
Visits: 113.5K
This is good news, thankyou Ted for all the time and effort you put into this evaluation. I'll contact the folks at RGT with this information and find out where they may want to go from here. I for sure want one of these silicone gaskets to put on my problematic oil pan. I will post information as soon as I can....
Visits: 471
These style gaskets are great. I've used a similar design on trans oil pans and many other engines. I've found they are reusuable as well.
Does the RGT have a steel core or limiting spacers around the bolt holes?
Thanks for the update!
Visits: 113.5K
Ted's 2nd picture in this thread shows the gasket. There is not a steel core or spacers. That's more than likely why the manufacturer publishes a specific torque. If you go to their (Real Gasket Tennessee) web site they have for quite some time offered a silicone gasket for the FE engine which is very similar in appearance and design as the Ford Y-block oil pan. My personal experience with this type gasket was during my aviation days. RGT offers silicone gaskets for rocker covers that performed excellent, no leaks, the bolts held torque and we reused them over and over. These aviation rocker cover gaskets didn't have a steel core or limiting spacers either. My oil pan has been abused and over torqued through the decades a million times so it should be a good candidate, I believe, for such a gasket.
Last Active: 10 hours ago
Posts: 2.0K,
Visits: 131.2K
How long do you think it will be before this enters production? I would like to buy a few for my builds.
Visits: 113.5K
I'll pass on all information as soon as it becomes available.
Posts: 1.4K,
Visits: 2.0K
You might as well suggest that they make Y-block valve-cover gaskets as well.
Visits: 113.5K
Yes, rocker cover gaskets and/or valley cover gaskets could come from the center section of the oil pan gasket? I have no idea of how their manufacturing process is done but this would be worth mentioning.
Visits: 113.5K
Communicated with the folks at Real Gasket Tennessee today. They informed me the pan gasket should be on their web site by the end of next week and ready for sale by the end of the month. They are willing to produce other gaskets such as rocker cover gaskets and silicone gaskets for other possible applications on our Y-block engines.
Posts: 2.0K,
Visits: 131.2K
I got on their website and registered - looking forward to making this order as soon as they are available. Thank you for your work in all of this!
