Visits: 23.1K
Have any of you priced main bearings for a 312? Or rod bearings, rear main seals? I am really stunned at the price jump over the last couple of years. Main bearings for the 312 Y at Summit is now $349.99, and they don't list a rear main seal. My local parts store lists the main bearings for $489.00, and jobber is nearly the same as Summit. CASCO sells the rear main seal for $49.95 plus shipping and state tax, and Speedway's bearings are white box, so not sure of the brand. Even the SBC 2.000" rod bearings are $94.00 for a set for the offset ground crankshaft. The cost for a premium build is nearly double from a couple of years ago. Anyway, this may be my last Y build for the short term. Joe-JDC
Visits: 13.9K
| FORD > 1957 > THUNDERBIRD > 5.1L 312cid V8 > Ignition > Spark Plug | |
Copper / Nickel  | | ACDELCO R85TS Gold; Pre-Set Gap: 0.040" ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">InfoOE-Recommended Gap: 0.035"Choose | https://www.rockauto.com/catalog/images/prevIMGbig.png" onclick="cataloglite.Listing_InlineImageManualScroll("989", -1, false, false)" alt="<" title="Previous Image" style="display: block; vertical-align: top; max-height: 100%; max-width: 1.2em; cursor: pointer; margin: 0.1em;"> | " src="https://www.rockauto.com/info/341/19362245_Primary__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> |  |
| ($1.08/Each) | x1 | $1.08 | | Add to Cart | | DENSO 5005 U-Groove Conventional; Pre-Set Gap: 0.035" ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">Info(Only 4 Remaining) | | " src="https://www.rockauto.com/info/14/5005__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> | |
| ($1.51/Each) | x1 | $1.51 | | Add to Cart | MOTORCRAFT SP431A Copper ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">Info Gap: .035 (Only 1 Remaining) | https://www.rockauto.com/catalog/images/prevIMGbig.png" onclick="cataloglite.Listing_InlineImageManualScroll("991", -1, false, false)" alt="<" title="Previous Image" style="display: block; vertical-align: top; max-height: 100%; max-width: 1.2em; cursor: pointer; margin: 0.1em;"> | " src="https://www.rockauto.com/info/48/SP431A-ANG__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> |  |
| ($1.81/Each) | x1 | $1.81 | | Add to Cart | | CHAMPION 11 Copper Plus ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">InfoOE-Recommended Gap: 0.035"Choose | | " src="https://www.rockauto.com/info/12/CCH_11_P04_FRO__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> | |
| ($1.86/Each) | x1 | $1.86 | | Add to Cart | NGK 2438 V-Power; Pre-Set Gap: 0.040" ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">Info OE-Recommended Gap: 0.034" | https://www.rockauto.com/catalog/images/prevIMGbig.png" onclick="cataloglite.Listing_InlineImageManualScroll("993", -1, false, false)" alt="<" title="Previous Image" style="display: block; vertical-align: top; max-height: 100%; max-width: 1.2em; cursor: pointer; margin: 0.1em;"> | " src="https://www.rockauto.com/info/100/NGK2438-1__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> |  |
| ($1.97/Each) | x1 | $1.97 | | Add to Cart | MOTORCRAFT SP431 Copper ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">InfoGap: .035Choose | (Only 5 Remaining) ($4.00/Each) x1 $4.00 | | |
| https://www.rockauto.com/catalog/images/prevIMGbig.png" onclick="cataloglite.Listing_InlineImageManualScroll("994", -1, false, false)" alt="<" title="Previous Image" style="display: block; vertical-align: top; max-height: 100%; max-width: 1.2em; cursor: pointer; margin: 0.1em;"> | " src="https://www.rockauto.com/info/48/SP431X-ANG__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> |  |
| ($4.00/Each) | x1 | $4.00 | | Add to Cart | Iridium (lasts up to 4x longer than Copper / Nickel)  | | NGK 7510 Iridium IX; Pre-Set Gap: 0.040" ; AddSerializedCookieDataToHref(this);" style="color: rgb(255, 255, 255); cursor: pointer; text-decoration: none; text-align: center; margin: 0px; padding: 2px 5px 1px; border-width: 1px; border-style: solid; border-color: rgb(124, 124, 174) rgb(22, 22, 55) rgb(22, 22, 55) rgb(124, 124, 174); border-image: initial; font-weight: 400; font-size: 12px; background: none rgb(51, 102, 204); vertical-align: middle; line-height: 1; appearance: none; border-radius: 3px; width: auto; overflow: visible; display: inline-block; box-shadow: rgb(85, 85, 85) 1px 1px 1px;">InfoOE-Recommended Gap: 0.034" | https://www.rockauto.com/catalog/images/prevIMGbig.png" onclick="cataloglite.Listing_InlineImageManualScroll("995", -1, false, false)" alt="<" title="Previous Image" style="display: block; vertical-align: top; max-height: 100%; max-width: 1.2em; cursor: pointer; margin: 0.1em;"> | " src="https://www.rockauto.com/info/100/NGK7510-1__ra_m.jpg" alt="Part image" switch-to-highres="1" style="border: 1px solid rgb(153, 153, 153); display: block; max-width: 100px; max-height: 50px; background: rgb(255, 255, 255); margin: auto; cursor: pointer;"> |  |
| ($5.93/Each) | x1 | $5.93 | | Add to Cart |
| 0px 0px no-repeat;"> | 0px 0px no-repeat;"> | 0px 0px no-repeat;"> | 0px 0px no-repeat;"> | 0px 0px no-repeat;"> | 0px 0px no-repeat;">; return false;" tabindex="-1" style="color: blue; display: inline-block; height: 18px; width: 16px; cursor: pointer;"> ; return false;" id="navhref[983]" style="color: blue; padding-left: 1px; display: inline-block; vertical-align: top; margin-top: 2px; text-decoration: none;">Spark Plug Non-Fouler |
