Spark plug wires
Posted By slumlord444 2 Years Ago
slumlord444
Posted 2 Years Ago
Posts: 1.2K, Visits: 137.8K
I’m having trouble with my plug wires holding up with my FPA headers. Looking for a recommendation for a set that won’t break down with extreme heat and fit the 312 in my 57 T Bird.
Deyomatic
Posted 2 Years Ago
Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)
Posts: 294, Visits: 2.4K
Any chance you can post a picture or two of the engine?
Joe-JDC
Posted 2 Years Ago
Last Active: 5 hours ago
Posts: 772, Visits: 22.5K
http://forums.y-blocksforever.com/uploads/images/a20f5fd6-72db-4b5d-8d3e-e3d6.jpghttp://forums.y-blocksforever.com/uploads/images/0b551d7e-16b3-4dbd-9e8f-e51e.jpgWhat distributor?  If you are using a MSD distributor, the MSD 5553 or 5552 Street Fire wires are excellent.  You will need to cut them to fit, but that is not too difficult.  Joe-JDC
slumlord444
Posted 2 Years Ago
Using stock distributor and cap.
Posted 2 Years Ago
Posts: 1.9K, Visits: 194.9K
I’m running a set of reproduction wires on both the bird and the roadster, never had a problem with the FPA’s on the bird or even tighter headers on the roadster. Both with MSD or high output ignitions, and I saw the FPA’s starting to flow red on the chassis dyno. Stock mounting brackets.
Joe-JDC
Posted 2 Years Ago
Larry's Thunderbird's sells a stock replacement set of wires, and a performance set.  I have heard that there is a SBC set of wires that fits a 327/350 that runs the wires under the exhaust manifolds that will work just perfect on the Y.  Any SBC universal set with proper boot angles should work.  Joe-JDC
Posted 2 Years Ago
Guessing that would be the corvette set that ran thru the shields that went under the manifolds. Similar to the y block. Been a long time since I ran a set of those.
Posted 2 Years Ago
Posts: 1.8K, Visits: 306.3K
Have you considered plug wire heat shielding?
Can you show a photo(s) showing how the wires are running along the headers?
7mm or 8mm?
Posted 2 Years Ago
Straight boots or 90° spark plug boots?  Here are some pictures of Y’s with 90° boots and headers.
http://forums.y-blocksforever.com/uploads/images/cffd3a60-cc22-46c2-aca8-dd97.jpg
http://forums.y-blocksforever.com/uploads/images/b7e8cbde-4a0e-49d4-b099-ed9b.jpg
http://forums.y-blocksforever.com/uploads/images/e7557711-abbc-4ace-8b38-65e0.jpg
http://forums.y-blocksforever.com/uploads/images/8ba5c9e3-575f-44c0-b174-2b2f.jpg
http://forums.y-blocksforever.com/uploads/images/49161e34-1e70-4024-8fcf-7049.jpg
Posted 2 Years Ago
http://forums.y-blocksforever.com/uploads/images/43bf80c1-f325-4d6e-8c92-2da4.jpg
http://forums.y-blocksforever.com/uploads/images/c9ec0796-5468-41e1-a77f-8388.jpg
http://forums.y-blocksforever.com/uploads/images/cab9d0c0-3cb1-46fe-9351-3414.jpg
The shields I mentioned previously are individual wire sleeving(s). There are also HI-TEMP BOOTS available.
Anyone remember PACKARD 440 wires and RAJAH CLIPS? HOT STREET, had to have 'em ...
