Wanted 1955-57 Thunderbird engine oil pickup tube
Posted By cokefirst 3 Years Ago
cokefirst
General Posted 3 Years Ago
Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)
Last Active: 8 days ago
Posts: 159, Visits: 2.4K
HELP, looking for a Y-block Thunderbird pickup tube that goes into the pan and connects to the oil pump.  This is a Thunderbird only part.  Thank you in advance for any assistance!
Posted 3 Years Ago
Posts: 3.7K, Visits: 497.9K
Check these vendors - they usually have used parts - CASCO, Hill's and Prestige
 A couple of others:
Adrian Lori   570-709-0823  PA
Tony's Classics   515-321-0767  Iowa
cokefirst
Posted 3 Years Ago
thank you sir
cos
Posted 3 Years Ago
Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)
Last Active: 11 hours ago
Posts: 198, Visits: 119.6K
Never given any attention to it but tube from truck may  work ??
Posted 3 Years Ago
Posts: 7.5K, Visits: 205.9K
I have both the Thunderbird and HD truck oil pans sitting here and was able to confirm that the oil pan oil pickup assemblies are the same for both.
cokefirst
Posted 3 Years Ago
Thank you Ted,  I have an F100 truck pan here with the tube and it is similar to the Thunderbird and it may work.  I bought a good used one and am getting my original repaired.  I will have an extra when I need it.  You can't have too many spare parts!
Posted 3 Years Ago
To be clear, there is a difference between the HD truck and all other truck pans and pickups.  If the f100 pan is correct for the f100, then that pickup is not the one you need.
You can see the differences at this link:
https://www.ford-trucks.com/forums/1355934-292-fluid-capacity.html
