Distributor clocking the wires
Posted By Richard 2 Years Ago
Posted 2 Years Ago
Posts: 3.7K, Visits: 497.8K
If it's the Mallory with the two piece cap, it may be easier to move the whole distributor.
Deyomatic
Posted 2 Years Ago
Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)
Posts: 294, Visits: 2.4K
I had to do that on a "SCRUB" engine I used to have where the distributor was next to impossible to get reinstalled.  Took me 2 hours one time...Well, it ran like garbage for a few weeks until I was introduced to the concept of "Total Timing."  I SHOULD have had around 32-36 degrees (if I recall) but I only had about 22...  Simple enough, I'll just spin this thingy here....BUMP- straight into the intake runner.
360 degrees in the Distributor's circle, divided by 8 is 45 degrees- so you're going to want to spin the dizzy 45 degrees in the opposite direction (evidently the only direction yours will move), then move each wire one spot in the direction these folks said (it's been a while since I timed mine so I forget which way to spin it) to get to the point where it will run...then
