Visits: 7.3K
I'm still around and still working on my old cars. My 56 Fairlane has drum brakes, I had them rebuilt, It is a vacuum assist system. When I first start the car the brakes are horrible, but after a couple of miles the car will stop on a dime. I suspect the vacuum cannister is bad or out of adjustment. Can I adjust the cannister? any ideas would be greatly appreciated. John
The vacuum check valves in the system would be at the top of my list.
Visits: 6.0K
I have had a vehicle in the past that the supply line connection at the intake was partially clogged. Make sure you have good supply of vacuum to the booster.
Visits: 7.3K
Thanks, I will check out both suggestions.
Visits: 7.3K
It was the cannister, the brakes are working great now. Thanks
