P.steering fluid
Posted By B-rad 2 Years Ago
B-rad
Posted 2 Years Ago
Posts: 348, Visits: 1.5K
My p. Steering pump says to add atf. Should I use power steering fluid or atf? I didn't know if p.s. fluid was even available back in 54. Plus, my tranny is getting rebuilt and I want to know what atf is recommended now.
Brad
Sierra Vista Arizona
1954 Lincoln Capri
mjs
Posted 2 Years Ago
Last Active: 8 days ago
Posts: 84, Visits: 123.8K
I've always used regular P/S fluid in mine with no trouble.  As to the transmission fluid my shop manual which covers 1955 - 1958 Lincoln Turbo-Drive and
1951 - 1958 Mercury Merc-O-Matic shows Type A.  Dexron/Mercon is a replacement for Type A but your rebuilder should be able to advise you.
http://forums.y-blocksforever.com/uploads/images/1d5b145a-1c57-4c0d-8bd1-fba5.jpg
Brent
Posted 2 Years Ago
Last Active: 10 Months Ago
Posts: 142, Visits: 1.5K
I was researching for the fluid to use in my ’55 Thunderbird PS system; the stock spec calls for Type A. I found this DEXRON - Wikipedia article to be very informative; Type A was a GM product… I contacted Lares Corp, they rebuilt my pump, valve and cylinder. They recommend using a “power steering” fluid without any stop leak additives in a system that has been rebuilt with modern seals.
Lares advises not to start the engine to prime a dry system, they recommend cranking the starter for 20 sec intervals. I dont want to grind on my starter so I came up with a pulley to use with a drill motor.
http://forums.y-blocksforever.com/uploads/images/861ba55d-a61e-47e0-bd39-c25b.jpg
cardonetesting.pdf (218 views, 517.00 KB)
FORD DEARBORN
Posted 2 Years Ago
Posts: 789, Visits: 113.4K
That's a keeper - nice one.
HazardTBird
Posted 2 Years Ago
Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)
Last Active: 9 Months Ago
Posts: 50, Visits: 1.3K
That sounds like a really good way to test everything in the steering system for leaks and operation before during initial startup and breakin of a freshly rebuilt engine!
Posted 2 Years Ago
Posts: 3.7K, Visits: 497.8K
The Tbird people advice is don't use power steering fluid.  Stay with ATF.  Supposedly, power steering fluid causes leaks in the old Ford system that ATF doesn't.
