Starter Questions...
Posted By Deyomatic 2 Years Ago
Deyomatic
Posted 2 Years Ago
Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)
Posts: 294, Visits: 2.4K
1.  How important is this "starter seal?"  There wasn't one behind the old starter so I ordered a new one but now find out it's back-ordered.  If it IS important...can I just goop on some Form A Gasket or RTV around the connection?
2.  Turned out the housing on my old starter where there is some kind of bushing or retainer on the shaft in front of the gear has a crack around it and I didn't think that the person that would rebuild it would be able to use it again or that I'd trust it...not to mention that I just didn't get the chance all week to even get over there...I went with one of the Powermaster mini-torque starters for a few reasons.  http://forums.y-blocksforever.com/uploads/images/d6ffda12-a2c3-446b-92b4-a56b.jpg
How do I wire it up and KEEP the Ford Solenoid on the firewall?
DANIEL TINDER
Posted 2 Years Ago
Last Active: 5 hours ago
Posts: 1.7K, Visits: 154.2K
A new seal almost makes installing the starter a two-man job.  Unless you drive a lot in bad weather or on gravel/dirt roads (or have 3 hands😁), you may not want to bother with it (I suspect dealership mechanics routinely didn’t).
6 VOLTS/POS. GRD. NW INDIANA
Posted 2 Years Ago
Last Active: 41 minutes ago
Posts: 3.7K, Visits: 323.2K
Since that is not an original Y starter, it is possible that the original seal will not fit anyway.
Posted 2 Years Ago
Last Active: 16 minutes ago
Posts: 3.7K, Visits: 497.8K
I don't use the seal.  Been out in bad weather and no problems.
Deyomatic
Posted 2 Years Ago
I got the starter today and stuck it in...It's in a Model A with no hood sides so it was likely the easiest Y block starter replacement in history.
There is probably a 1/16" or so gap between bolt holes that junk could get in there...especially with an open hood.  There's a seal on the way but I think I may try it out and make sure it works, then run a bead of black RTV over the gap (like caulk) just to be safe.  It's cruising season, after all.
2721955meteor
Posted 2 Years Ago
Posts: 927, Visits: 190.0K
the gasket is more to making the starter quiet, with no gasket they sound like they will fail. not the case. never had a issue installing starter, do not engage the gear makes job easier
Posted 2 Years Ago
You need to show us a photo!
Deyomatic
Posted 2 Years Ago
I ended up doing exactly what I suggested...used some Form A Gasket as if it was caulk and it's all set...
Of course, I had ordered a couple of those Starter Seals but never got a confirmation that they were in...so I ordered another one just to get it in my hands before I just "caulked" the gap...
Long story short- now I have 3 of them...so if anyone needs a starter seal, hit me up!
