B-rad
Visits: 1.5K
After swapping out the distributor, oil pump, distributor gear and shaft, I find the intermediate shaft is about 1/2" too long. Is it advisable to shorten the shaft? If so, too or bottom better and how?
I’d leave the more pointed end alone.( Distributor end) I would use a pedestal or bench grinder. Don’t take much off and continue to test fit. I’m not familiar with the Lincoln if that’s what you’re working on. I check my Ford by removing the oil pump cover, sliding off the idler gear, and working the length with the driven gear. My intermediate shaft doesn’t have the sliding washer on it so everything can be done thru the oil pump. You need some room for expansion. It’s all easier with the engine on a stand. Good luck.
B-rad
Visits: 1.5K
Yeah. I have the distributor in and locked down, flipped the engine over and inserted the shaft. When putting the pump on, it won't go down to the block. Little by little sounds good to me. Was concerned about heating it up and weakening the shaft. What's supposed to happen with the sliding washer on the shaft?
Visits: 497.8K
Make surr the sliding washer is in the correct position and not preventing the shaft to go up enough
B-rad
Visits: 1.5K
What is the correct position?
Posts: 7.5K,
Visits: 205.8K
The LYB oil shaft should be in the neighborhood of 9.167” overall length. The retaining washer if still on the shaft should be at the lower end of the shaft and not at the top. Gut feel says the shaft is not going into the lower end of the distributor. Did you try the oil pump intermediate shaft in the distributor before putting the distributor in the block? There’s a good chance that the hex hole in the distributor was also damaged when the bottom of the shaft was damaged when changing out the distributor gears.
B-rad
Visits: 1.5K
I did put the shaft into the bottom of the distributor shaft, i had to clean it up a bit but it goes in. After I slid the oil shaft up into the distributor, I slowly turned the engine over and the oil shaft turned. I figured that meant the two were seated together. I thought I read somewhere that the shaft would be too long when making this swap
B-rad
Visits: 1.5K
A little off topic, just want the info... Which direction does the crank turn when the engine runs? And the distributor? Putting the plug wires on soon and making sure the wires go on ccw.
Dobie
Visits: 22.0K
Viewed from the front of the engine the crank rotates to the right. The 'strib rotates the opposite direction, CCW.
B-rad
Visits: 1.5K
Not sure what I did this time but the shaft went in far enough. Got the oil pump installed. Glad I took my time and didn't rush to cut the shaft. Not like me, usually I rush things.
