Visits: 1.5K
 Been trying to get my distributor put in and it's been a struggle. I thought I finally got it in but now see a set screw looking thing up against the distributor gear. It's facing the lifter on the eighth cylinder I think. What is it and why is it interfering with the distributor gear? Can I just screw it in further or is it supposed to be there? I tried gently turning the engine around a bit but it is not moving.
Visits: 1.8K
If you remove the set screw, then fully seat the distributor, will there be enough space to reinsert the set screw without it interfering with the distributor? Does the 54 Lincoln engine otherwise have an external distributor hold-down clamp? If the set screw takes the place of a hold-down clamp, like the hold-down clamp, it doesn't go in/on until the distributor is fully seated.
Visits: 1.5K
It does have a clamp thing on the top of the block.
Removed. Not realizing what the the question referred to.
Last Active: 4 Months Ago
Visits: 16.7K
Looks to me like that is a plug on the end of the lifter oil gallery Just screw it in further
Visits: 113.4K
I agree that is looks like an oil galley plug that should be a flush or close to the surface type plug. They are available in various thicknesses. The shop probably didn't realize a distributor gear needed to clear that plug. I did look at a basic picture of the oiling system of a Lincoln Y-block and it does look like there is an oil galley front to back at each lifter bank.?
Visits: 1.5K
Thanks y'all. I didn't know if there was a specific amount of tightening that plug needed to be and didn't want to mess it up
Last Active: 8 days ago
Visits: 123.8K
Ah that dreaded plug. I ran into the same issue with my 368. I always thought it was a Y-Block issue but it must be unique to the LYB'S. That plug goes into the oil galley. When I had the motor for my Convertible rebuilt the mechanic replaced it with a pipe plug. I snapped two drive gears before I discovered the issue. That plug uses an Allen wrench to tighten it up. On the back of the block there will be a small soft plug that lines up with it. Pull the plug, screw it in a little further, and replace the plug. In my case I already had the motor and transmission in the car. I had to remove both and unbolt the tranny to get to it. I went to Ace hardware and they had what I needed. I even ground down the head to give myself more clearance. When I called my mechanic he knew exactly what plug I was talking about. He was wondering why it had such an odd plug. Fortunately I have a local parts shop who had the gears in stock..
Visits: 1.8K
"For want of a nail..."
B-rad, aren't you glad you know now?
Visits: 1.5K
It's good to know it's an Allen wrench head. I didn't really want to remove that plug cuz I didn't want to damage it and not sure how to reseal it. It has some gray goop sealing it.
