So what's this screw thing?
Posted By B-rad 2 Years Ago
Posted 2 Years Ago
Posts: 3.7K, Visits: 497.8K
Go firing order, clockwise starting with # 1 (assuming Lincolns turn the same way as a Ford)
  uote]B-rad (4/13/2023)
Well, I ground the head down and now the distributor slid right in. I had the #1 piston at tdc and lined the rotor up with the number one on the cap. Gonna make sure the vac adv is facing the carb.
What direction do I go when putting the wires on?
[/quote]
FORD DEARBORN
Posted 2 Years Ago
Last Active: 4 days ago
Posts: 789, Visits: 113.4K
Looking at the top of the distributor cap it's counterclockwise starting with #1 and follow the firing order. To my knowledge all Ford V8's are CCW.
B-rad
Posted 2 Years Ago
Posts: 348, Visits: 1.5K
Well that's one cw and one ccw. Tie breaker anyone?
Plus the intermediate shaft is a little bit too long, it's not a problem cutting a half inch off the bottom is it?
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 2 Years Ago
Last Active: 7 hours ago
Posts: 3.7K, Visits: 323.2K
CCW is the direction for Y-Blocks, and since Lincoln and Y Block distributors interchange with a gear change, Lincoln also have to rotate CCW.
