Visits: 1.5K
Anyone know if window motors for a 56ish fomoco will fit my 54 Lincoln Capri? I'm going to be converting the car to 12 volt and think converting the power window motors will be a good idea. They are all just sitting in the bottom of the doors, not installed so I don't know if they work. The wiring are really frayed so I can't get them to work by hooking up to a battery.
Visits: 22.0K
Ford used the same motor for anything with power windows/seats into the late 50's/early 60's They're very stoutly built so I 'd bet your 6 volt ones are operable. They will work fine on 12 volts, just keep your fingers out of the way when raising the glass. You can use heat shrink to insulate the frayed wires; I just went through all this on my '55 Merc.
Visits: 1.5K
Thanks. Appreciate it. Is there a way to replace the wires? How do I test them with a battery? Not sure what hooks to what
Visits: 22.0K
Replacing the wires would require disassembling the motors, a job best left to a pro. There is no way I know of to test them on the bench.
A wire diagram for your car, especially one from ClassicCarWiring.com in color, will show you connection points and the original colors of the wiring. In the utility business it’s also known as an elementary drawing and used for troubleshooting.
Visits: 1.5K
Wow. Those diagrams are pretty cool. Since I'll be rewiring the whole car and converting to 12 volts that diagram is something I'll be getting. Thanks for the heads up.
