Y Block Truck bell housing with mount for slave cylinder
Posted By Daniel Jessup 2 Years Ago
Daniel Jessup
Posted 2 Years Ago
Posts: 2.0K, Visits: 131.0K
Cleaning some things out of inventory - these bell housings for the trucks are heavy I know, but I thought maybe someone could use it. I can send more photos if you shoot me an email at dan.jessup@hotrodreverend.com.
$60 plus the ride to your door - I am in Milford, Ohio 45150.
http://forums.y-blocksforever.com/uploads/images/1379d07e-3230-47fb-9858-5d4.jpeg
Daniel Jessup
Lancaster, California
famdoc3
Posted 2 Years Ago
Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)
Last Active: 10 Months Ago
Posts: 178, Visits: 21.8K
The thing you’re call a “mount” is the slave cylinder itself just missing the piston and seals. Have that setup in the hot rod I’m building. Mike
Daniel Jessup
Posted 2 Years Ago
famdoc3 (3/3/2023)
I did not know that - it had looked like there was an "ear" on the bell that I had not noticed on earlier bells for the Y block. I guess I will have to get it out again and take a look see.
http://forums.y-blocksforever.com/uploads/images/f48a55a7-2a6a-4166-89f0-1a4.jpeg
Daniel Jessup
stuey
Posted 2 Years Ago
Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)
Posts: 443, Visits: 3.8K
Hi
That bell housing may be quite desirable to someone.
http://www.ford-y-block.com/t5in-trucks.htm
stuey
Posted 2 Years Ago
Early trucks did not have a hydraulic clutch so the bellhousing does not have that mounting ear.  '57-'60 used a hydraulic clutch, as well as larger '61-'64 trucks so the same design stuck around from '57 on.
