peeeot
Visits: 25.6K
I've put 3300 miles on my Crestline since purchase. I have tracked every fill-up and my overall average is 15.3 miles per gallon. My odometer is GPS-verified to be accurate, so I believe this is real and honest fuel economy. The past several tanks have all been almost exclusively highway miles (commuting to work around 65-70 MPH). With overdrive, my tach is reading a little under 2500 rpm at this speed. Economy on these tanks has been 15-16 MPG. Worst tank I have ever recorded was 13.93, best 19.24 (once--thinking may not have filled the tank as full as usual).
Does this sound about right?
Posts: 1.4K,
Visits: 2.0K
I'm wondering about 2500 rpm at 65/w overdrive. What is your axle ratio? Is your 312 stock? Of course, the overdrive will not help your town mpg.
FORD DEARBORN
Last Active: 33 minutes ago
Visits: 113.5K
Yes, this sounds about right. I am in that ball park too. 15 to 17 mpg if I drive normally. 1964 F100 312 mild cam, 3.5 rear end T5 trans and fairly large diameter tires. My engine turns about 2100 rpm at 70mph. I bet if we could burn fuel as it was in the day, our mileage would be at least 2 mpg better. But does it get any better than driving behind a fine running Ford Y-block?
peeeot
Visits: 25.6K
Axle is a 3.9 ratio and the 312 is stock. It’s a bit tired but runs really well. According to my calculations, given my tire size, 70 mph should come in at 2370 rpm, and that seems about right for what I see on the tach.
I’m thinking the car could do upper teens to 20 if I was driving around 45-55 mph without stop-and-go.
Posts: 1.4K,
Visits: 2.0K
2370 at 70 sounds better. I think your mileage is in the ballpark.
292. Stock. 2.74 gear. Cruise-O-Matic. 27” tire. 12 mpg over 11 years of city driving. Can get 13.5 on hyway, but it’s always combo.
Posts: 1.4K,
Visits: 2.0K
DLR, unless you've got the "pedal to the metal" on the highway, your mileage concerns me. I would check your air:fuel ratio.
Always been that. Even with single stock 4 barrel. Dual quads,Carter WCFB’s, made no difference. I drive with a very light foot. Automatics with the heavy converter we’re always as bad even in the 50-60’s with stop and go like 99% of mine is. Exhaust is very clean. Thru bumper exhaust tips are never black or sooty..ever. I’m not going to add a bung for an analyzer. I’ve never driven a full tank out on the hyway. I also keep a log on every tank fill up which is usually every 3 months.
Visits: 39.4K
peeeot
Visits: 25.6K
Moonshadow, is your odometer accuracy verified? My first two tanks were over 17 MPG but that was with a 20-tooth gear. It was optimistic. I have a 22-tooth now and its within 1% of GPS every time.
Do you know you carburetor, jetting, and cruise spark advance? Just curious!
