Putting engine on stand
Posted By B-rad 3 Years Ago
Richard
Posted 3 Years Ago
Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)
Last Active: 7 Months Ago
Posts: 410, Visits: 81.0K
I’ve had this problem.  The bracket on the engine looks good, just make sure the round mounting tube ends up so the engine angled up, not down.
Jack up host and mount engine stand so the whole is airborne. Put the locating pin in. Since it’s all in the air you can slowly lower it maneuvering it to a safe landing. It’s good to have another person to maneuver the engine and one lowering the host.
Good luck
B-rad
Posted 3 Years Ago
Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)
Posts: 362, Visits: 1.5K
Great idea Richard. I'll be trying that later
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 3 Years Ago
Last Active: 6 days ago
Posts: 4.6K, Visits: 39.5K
The stand you are using is more stable but the long front legs are the problem (duh, thanks for the pictures). Maybe you can set the engine down on something and come in from the side with the hoist?
FORD DEARBORN
Posted 3 Years Ago
Last Active: 3 Weeks Ago
Posts: 852, Visits: 113.5K
Seeing that your engine is mostly assembled already, why bother with the stand. I'll TRY to send a pic of my 312 mounted between the legs of my portable shop hoist in preparation for the initial run-in which worked out excellent. I have also done this procedure with a 302 engine.  Here I am hooking up the electrics for the run-in. http://forums.y-blocksforever.com/uploads/images/5e11a521-1ae8-4786-b15a-92fa.jpg
57RancheroJim
Posted 3 Years Ago
Posts: 729, Visits: 112.0K
I feel your pain, I have the same issue and I built the hoist and stand myself. It worked fine for the 223 six I was pulling from my truck at that time but then when I used it for the Y block in my 57 the legs on the hoist are about 10" to long. Sad I have put the cross leg of the engine stand on top of the legs of the hoist.
57RancheroJim
Posted 3 Years Ago
FORD DEARBORN (1/20/2023)
I like your run in stand. I made one out of mostly scrap. It has a  fuel tank added now.http://forums.y-blocksforever.com/uploads/images/9972caf5-3720-4e32-8220-91dd.jpg
Posted 3 Years Ago
Posts: 3.7K, Visits: 498.3K
Another possibility - drop the engine to the ground, disconnect from hoist.  Raise hoist on something so the stand legs go under the hoist legs.  Raise engine by hoist, slide stand under legs, attach stand to engine.
Posted 3 Years Ago
I would use extreme caution if you attempt to "Raise hoist on something." I tried doing that with a floor jack; it didn't stay put, but no damage was done.
B-rad
Posted 3 Years Ago
Got it on the stand. Thanks for all the advice. Now to paint and assembly.
Brad
1954 Lincoln Capri
Posted 3 Years Ago
Last Active: 4 days ago
Off the subject..Always baffles me why Ford, with the introduction of the overhead valve 239/254, the engineers didn’t use the port design they already had with the Lincoln. It had to be $$$$ or wanting better for the more prestigious car.
