Visits: 1.5K
Update: The adjusting screw with the nut backed off is very loose in the rocker; they can be wiggled side to side in the rocker arm. I suspect either the diameter of the adjusting screw and rocker arm don’t match or there is excessive wear. I can’t imagine the adjusting screw should be so sloppy when threaded into the arm. It is tricky to get the correct lash set; when locked down the adjuster moves up as the threads mesh/grab. I have ECG rockers with adjusting screws and lock nuts, is there a torque value for tightening the lock nut? Seems like there is a potential for the nut to loosen while running the engine. I found this post: Rocker adj nuts
Visits: 285.6K
I have been using locking nuts like this for years. I hand snug mine with a wrench and have never had one loosen in street driving. I suppose you could put a dab of Loctite Blue on them if necessary.
Visits: 1.5K
Posts: 1.9K,
Visits: 194.9K
I’ve never had a problem with the locknuts coming loose. It you couldn’t move them with your fingers, I don’t think you do either.
Do a hot reset to the isky specs, and run it till hot. With everything being the same, I wouldn’t lose sleep over the cam until I checked it again. I’ve lost cams before, and they were all over, some fine, some more .050. Never the same and so little change. There’s a lot of parts there with clearances, assembly lube, etc. Maybe make sure the pushrod cups are correct for the adjustment screws. I’ve done that wrong, but they usually split.
