Correct upper control arm assembly
Posted By B-rad 4 Years Ago
B-rad
Posted 4 Years Ago
Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)
Posts: 362, Visits: 1.5K
I'm really confused now. I'm posting a screenshot of a video I shot before I tore it apart. This is the driver's side and clearly the stops are not against the washer it's on the other end of the shaft. Unless being a different year makes a difference
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 4 Years Ago
Posts: 2.0K, Visits: 306.7K
"I'm really confused now. I'm posting a screenshot of a video I shot before I tore it apart. This is the driver's side and clearly the stops are not against the washer it's on the other end of the shaft. Unless being a different year makes a difference"
Don't feel like the LONE RANGER ...
With the original photo it is showing something different than what I thought -
This photo is the driver's side (LS)?
http://forums.y-blocksforever.com/uploads/images/34f6617d-aeaa-4566-b620-ba27.jpg
If you notice, the front bushing (3068) has no inner washer (3091) to hold it in place on the shaft. It is held in place by the 'ears' being discussed being against the inner metal sleeve on the bushing. So therego, the 'ears' on the shaft will face forward on either side of the car.
The rear bushing is encapsulated by two retaining washers, front and rear. The front bushing uses only one retaining washer in front and the 'ears" at the rear of the front bushing. The bushing inner sleeve failed and allow the bushing to move destroying the actual insulator.
The two bushings (front and rear) are different on the '54.
CORRECTION - The bushing itself is being held on the inner side by the bushing inner sleeve going against the machined stop at the end of the shaft, Those 'ears' purpose must be to try preventing the rubber insulator from moving inwards if the inner sleeve slides/fails.
You can see where in the insulator has been wallowed by the up and down movement of the control arm.
So what I said originally is wrong. This (photo) (OP) is correct. I wish I had the 54 LINC WSM.
Damn I hope the above is understandable. I only went to the 3rd Grade (twice).
Posted 4 Years Ago
OK, I now see a discrepancy in the 57 LINC photo.
http://forums.y-blocksforever.com/uploads/images/d0eec3e3-4c71-487a-a07d-a2e7.jpg
Everybody take their pack off and stand easy for a while. Smoke 'em if you got 'em ...
B-rad
Posted 4 Years Ago
So it is confusing. What could happen if they are installed incorrectly? Both arms move easily as they are
Brad
1954 Lincoln Capri
Posted 4 Years Ago
I am fairly certain what you removed is correct assy.
The worst thing would be the inability to set caster/camber properly (and that includes the bushings which are different for the 52/53 and the 57.  If the upper and lower arms were assembled with the spindle and without the spring and the assy moved up and down easily, you should be good. You won't know until you attempt to align and drive (if the springs are not weak and not able to get to factory setting trim height).
It is not known which setup photo (54 or 57) is correct but if you cipher on it long enough, what you started with seems correct (to me). The 1954 MPC 1954 and 1957 MPC ILL's are basically the same but they use modified ENGINEERING DRAWINGS to the extent of not showing exact application but just give a general idea (multi-year)  so the PARTS DUDE can identify the BASIC PART NUMBER to find in the TEXT.
The WSM will show a true ENGINEERING DRAWING (abbreviated) along with a photo usually.
Are you able to scan the WSM pages and post them here?
B-rad
Posted 4 Years Ago
What's wsm?
Brad
1954 Lincoln Capri
B-rad
Posted 4 Years Ago
If it's the shop manual I'll it's basically the same as what was posted by someone else on here earlier. If the stops were shown it would be cut and dry as to the placement of everything
Brad
1954 Lincoln Capri
mjs
Posted 4 Years Ago
Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)
Posts: 84, Visits: 123.9K
Here is a photo of the driver's side upper A arm taken at about the same angle as yours. As you can see the large retainer is at the rear bushing.  Interestingly my interchange catalog lists the upper A arms being the same from 52 through 57.  Moog also shows them using the same bushings.
http://forums.y-blocksforever.com/uploads/images/5a8e7f38-aa77-4683-9449-7812.jpg
http://forums.y-blocksforever.com/uploads/images/8527483c-f414-47cc-a112-096f.jpg
http://forums.y-blocksforever.com/uploads/images/2cabf0b3-1024-443f-8fc9-c68a.jpg
http://forums.y-blocksforever.com/uploads/images/1d5b145a-1c57-4c0d-8bd1-fba5.jpg
B-rad
Posted 4 Years Ago
So if you go by the pic of my green arms, they're correct?
Brad
1954 Lincoln Capri
Posted 4 Years Ago
"So if you go by the pic of my green arms, they're correct?{/b]
IMO, yes.
