Looks like a trip to the machine shop is in my future...
Posted By Tealy64 3 Years Ago
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
If I understand you correctly, wouldn't it be easier to start with a coping saw blade?
55 GLASS TOP
Posted 3 Years Ago
Posts: 389, Visits: 31.8K
Tell you what I have done with broken bolts that just would not come out . Take a hacksaw blade grind the back away about one inch long grind it to the width of the hole you have drilled . Put the hacksaw in the hole saw through the bolt once you have a cut in the bolt it will collapse in the hole and come out . Sounds crazy but it works for me
Posted 3 Years Ago
I had good luck extracting a broken bolt with a Rescue Bit (rescuebit.com). I was able to remove the broken bolt, and the threads were still intact. I was able to replace the broken bolt with the same size bolt & thread pitch. The bits aren't cheap; however, being double-ended, they have a longer lifespan. You might want to try it before removing the head and taking it to a machine shop. Be sure to follow directions, and let the bit do the work.
Joe-JDC
Posted 3 Years Ago
Posts: 772, Visits: 22.6K
Drill it larger and larger to get enough area for an "easy out".  If you need to remove the threads, then re-tap it for a heli-coil.  Should be something you can do at home if you have the room to get at it with a hand drill.  Joe-JDC
Tealy64
Posted 3 Years Ago
Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)Supercharged (172 reputation)
Last Active: 5 Months Ago
Posts: 49, Visits: 1.3K
This bolt broke off in my head while taking the manifolds off. Tried cooking for days in deep creep, tried heat, welding a nut on it, drilling, etc. It just keeps destroying my tools. 😩
If I'm taking them off and over to a machine shop, what else should I have them do?
Looking for advice and suggestions.
1964 Ford F100 w/ 292 Y-block
-Central Florida-
