Headlights for 12volt conversion
Posted By B-rad 3 Years Ago
B-rad
Posted 3 Years Ago
Posts: 348, Visits: 1.5K
Thx miker. Still flipping the coin here. The car has no radio currently in it so that's no issue. I would like to be able to charge a phone too. Does anyone know how to go through the window motors or at least check them for usability? Everything in this car was unused for 57 years so there's no telling what condition they're in.
Hey Mike, your in Tucson some of the year? You're not that far away.
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 3 Years Ago
Phone charging may be possible on a 6v system.  Most phone chargers are based on USB specifications, which usually provide a 5v output.
alanfreeman
Posted 3 Years Ago
Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)
Posts: 368, Visits: 5.4K
These old power window and seat motors are very rugged.  I have seldom found one that doesn't work as they are usually good.  Just hook the leads up to a 6 volt battery and test if they run in both directions.  My bet is that they will work.
FORD DEARBORN
Posted 3 Years Ago
Posts: 789, Visits: 113.4K
You will probably find the DC motors in need of attention as was the case when restoring my 64 F100.  It too spent it's life in the south west and the wiper- blower motors had little to no wear at all.   However, the oilite bushings and gears were in serious need of lubrication with old hardened dried out grease. Not something those motors will be happy with for very long.   Your shop manual may show how to service them or it can be a subject for another thread.
Posted 3 Years Ago
Posts: 3.7K, Visits: 497.8K
To charge a phone in your car, there are adapters  that plug into the cigarette lighter.  Can find them most any where.
Posted 3 Years Ago
While staying with the 6 Volt system does present somewhat of an issue, it would appear that in your case, going to 12 Volt will be even a more of a pain & expense then it's worth.. It's now a collector vehicle..  I suggest you go with it..
cokefirst
Posted 3 Years Ago
Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)Supercharged (391 reputation)
Posts: 158, Visits: 2.4K
I agree on keeping the system 6 volt.  With all the accessories, you are going to have a big job changing everything over if you do decided to go 12 volt.  You may want to consider a Power-Gen alternator that looks and fits like the original generator.  It is a 1 wire alternator and you want the one with 3 connections if you want the generator light to work.  I have these on my fleet of Mid 50's Fords and I LOVE it.  I leave the regulator there and cut the internals so that the regulator is just a junction for the wires.  I use the original harness from the generator to the regulator and I find they keep my systems running and trouble free.  I have one on my 57 Skyliner that has power windows, seat a and factory air.  My only complaint is that you need to make sure that the nut holding the pulley is on tight.  I had to use my original pulley because it is a double pulley for the car with factory air and I did not get the nut on tight enough.  They do not machine the shaft for the woodruff key and it will slip if not tight.  I spoke to them about this and they said it was unnecessary to have the shaft machined for the woodruff key but I disagree.  In any case, the problem is solved if you tighten the nut accordingly.
Posted 3 Years Ago
I don' t agree on the 6V vs 12V.  Going to 12 volts opens up a lot of oppertunities for add ons such as air, better radios, etc.  Not that expensive to do a change over..  If wires are in good shape no reason to change them. 12V will work with 6V gauges if you use the Ford voltage reducer.  6V starter works good on 12V.  Using a  standard alternator instead of the fancy ones that looks like a generator  means you can get a replacement anywhere when it goes south.
B-rad
Posted 3 Years Ago
I'd still have the power seats, windows and ac that are 6 volt. I heard the windows and seats will work with 12 volt, just faster. Does anyone know how to see if the ac compressor will work with 12 volt? What about interior lights, head and tail lights,turn signals? Just change the bulbs to 12 volt?
Brad
1954 Lincoln Capri
FORD DEARBORN
Posted 3 Years Ago
My thoughts as to the DC motors is if the voltage is doubled, the current will rise significantly creating a lot of heat. Those motors will eventually fail. Especially when in a stalled condition such as when the seat or a window reaches the end of it's desired travel.  The same switches that were designed for 6 volt motors will also be subjected to the additional current. A 12 volt motor has higher resistance than a 6 volt motor so the current stays in check when the voltage is matched to the task. I would also think the additional torque applied to the mechanism's may eventually have a negative effect also.  As for the A/C clutch coil, it too will run hotter on 12 volts but unlike seat and window motors, it's use will be constant as opposed to a couple seconds duty time for seat or window motors.   I'm guessing the accessories in your Lincoln car will be in good shape for wear and after a thorough cleaning/lubricating should work very well. You could keep the 6 volt system at least until the vehicle gets on the road then make a decision. I believe someone mentioned there is a 6 volt alternator? If so, then that should help maintain a more constant voltage at idle. Are there 6 volt led head light and tail light bulbs? If there are such a bulb, they would draw 1/10 the current incandescent bulbs pull and provide better lighting.   Just some possibilities and food for thought, nothing more.  Nice Lincoln car you have in remarkable condition.............
