What PCV valve to use
Posted By seishank65 4 Years Ago
seishank65
Question Posted 4 Years Ago
Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)
Posts: 34, Visits: 2.5K
What PCV valve should I use if doing the install that oldcarmark mentioned on a post.
quote]oldcarmark (11/10/2022)
I used the Moroso Baffled Grommet on mine. 4 Years works fine. No excessive Oil usage. You can use that with the existing Valley Cover. Just use a Hole Saw to cut proper size Hole. I used the correct Grommet that fits PCV and Super Glued it inside the Moroso Grommet.[/quote]
