SPEED O GEAR
Posted By darrell 4 Years Ago
darrell
Posted 4 Years Ago
Posts: 457, Visits: 22.3K
i have a 390 rear.how many teeth do i need on the speed o gear.its in a 55 but im using a 58 trans so had to go to a newer cable.thanks
Posted 4 Years Ago
Posts: 3.7K, Visits: 498.2K
There is a formula that takes account of the gear ratio and tire size, but I don't have it.
Have you tried it with he current gear? how much are you off ?  If so, count the teeth on the current gear.  More teeth slows the speedo, less teeth make the speedo faster.  Each tooth represents about 4-6 mph..  New gears are available - try ebay - lots of them on there.
FORD DEARBORN
Posted 4 Years Ago
Last Active: 7 days ago
Posts: 840, Visits: 113.5K
http://forums.y-blocksforever.com/uploads/images/6af43737-eed2-4434-94a3-61f2.jpg
FORD DEARBORN
Posted 4 Years Ago
This is thre best I can do, maybe someone could size it a little better.   It's the formuila from an NPD truck catalog. NPD also has many Ford speedometer gears.  Hope this helps.......
darrell
Posted 4 Years Ago
im fast so i need more teeth.i found that out yesterday.ill start from there.thanks
Posted 4 Years Ago
                    Maybe this is clearer - and right side uphttp://forums.y-blocksforever.com/uploads/images/6ebcf5d8-41ee-4af4-8655-4d20.jpg
FORD DEARBORN
Posted 4 Years Ago
Thanks Paul and BTW, I have used that formula twice - very handy.
