Visits: 81.0K
The Best Gasket Neoprene seal instructions say to loosen all the main bearings caps before installing the seal components. This sounds logical but just thought I’d check it out here.
Last Active: 6 minutes ago
Posts: 3.6K,
Visits: 497.7K
That's so you can slide the top half of the seal in
Visits: 190.0K
ARE YOU SURE THE REARSEAL IS LEAKING. MOST REAR SEAL LEAKS ARE THE OIL PANGASKET. THE PAN SHAPE AND THIN GASKETS ARE THE CAUSE IHAVE A KIT WITH THICKER PANGASKET,A WATER CUT PLATE FOR THE REAROF THE PAN TO BETTER SUPORT THAT ARIA. 100 US INCLUDES FRATE CAN SEND PICTURES IF INTERESTED. IF STAND TRANS REMOVE CLUTCH COVER AND RUN ENGINE AND WITH A GOOD LIGHT SHOULD BE OVEOUS WHER THE OIL IS FROM. CLIFF9 55 METEOR)
Posts: 3.6K,
Visits: 497.7K
Side seals can be the cause of an oil leak
