54 Lincoln dual exhaust
Posted By B-rad 3 Years Ago
ErnieL
Posted 3 Years Ago
Posts: 28, Visits: 9.0K
368 is the same block as a 317 so it should bolt right up
56 Meteor 4 dr hardtop
56 Meteor 2 dr hardtop
55 Sunliner
53 Lincoln Capri 2 dr hardtop
58 Skyliner
Anna, Tx
Posted 3 Years Ago
Posts: 3.7K, Visits: 497.8K
In a Ford, especially 54's, it was common practice to run a pipe down and back from the drivers side manifold (opening in the front) because either the neutral safety switch was in the way or the Z bar was in the way if using a later rear opening exhaust  manifold.  Sounds like what you are describing, but only on the passenger side.  Not familiar with the Lincoln exhaust system .
slumlord444
Posted 3 Years Ago
Posts: 1.2K, Visits: 137.8K
My 53 Ford Flathead had a wrap around pipe for duals that was available aftermarket. later model manifolds with rear outlets would make a much neater setup.
