Control arm damage
Posted By peeeot 4 Years Ago
peeeot
Posted 4 Years Ago
Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)
Last Active: 4 days ago
Posts: 359, Visits: 25.5K
I’m working on a 1959 Skyliner (FE-powered) that was driven far too long on failed lower control arm bushings. One bushing wore all the way through into the control arm, as seen below. Is this something that can be safely repaired, or should I be looking for a replacement arm?
Posted 4 Years Ago
Posts: 4.6K, Visits: 39.3K
I'm sure a good welder could fix it but I think I'd look for a replacement arm anyway.
Posted 4 Years Ago
Posts: 1.9K, Visits: 195.0K
I agree with MoonShadow, but around here a good welder and his time would probably cost more than finding one and shipping. I’d go for a good replacement, given the rest of the arm was good on it.
peeeot
Posted 4 Years Ago
Sounds like replacement is the way to go. At least they aren’t too hard to find!
Thanks for your input.
peeeot
Posted 4 Years Ago
Here is a separate, but related issue: when attempting to remove the passenger front control arm bolt, it was pretty stuck so I used a breaker bar on the head. I heard a couple of “tink” sounds and discovered that the inboard frame plate was rotating with the bolt. I was able to battle the bolt out of the frame eventually, but now I need to reattach the frame plate and am not certain how it ought to be done. There are two dimples that correspond with dimples on the frame, but they do not appear to have been a point of attachment. Any ideas?
Posted 4 Years Ago
Posts: 3.7K, Visits: 498.2K
Plug weld in back in.
Posted 4 Years Ago
A word to the wise if I may, since it's a suspension part, if going to re weld it, make sure the surfaces are properly de rusted & cleaned for welding..
... N.B.- Just noticed that this subject was some time ago, but it's worth mentioning anyway..
