Heater valve
Posted By peeeot 4 Years Ago
peeeot
Posted 4 Years Ago
Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)Supercharged (786 reputation)
Posts: 359, Visits: 25.6K
I order Four Seasons 74627. It fit perfectly and it definitely totally stops flow when in the off position. I’ll post back after I get to road test to see whether it solves the forever-heat problem.
Posted 4 Years Ago
Last Active: 6 days ago
Posts: 1.9K, Visits: 195.0K
Thanks for the number and response. I wish I’d thought to do that when I bought one. I guess I should admit while I don’t like plastic, I did have a whole car made out of it once.
Posted 4 Years Ago
Lego?
peeeot
Posted 4 Years Ago
I’m not wild about plastic parts either, but in this installation it’s hard to see, tucked up under the heater ductwork. If it works, I’ll happily live with it!
Posted 4 Years Ago
RE plastic heater valves, if it's OEM, it will probably be fine.  If it is aftermarket, probably for an older application, then possibly be prepared to replace it every couple years.
I made the mistake of replacing the original valve on my '88 Firebird as a preventative measure some time in the 2000s.  Since then, I've had to replace the Chinese aftermarket ones every year or two.  They all fail in the exact same way and start to leak.  Fortunately it's pretty easy to replace but I'd gladly pay a couple hundred for a quality billet aluminum unit if it was available.
Posted 4 Years Ago
Posts: 3.7K, Visits: 498.2K
Four Seasons has a metal one.  If your interested, its for salehttp://forums.y-blocksforever.com/uploads/images/0fcc7862-3f19-465e-aeff-16d9.jpg
peeeot
Posted 4 Years Ago
So far, the plastic valve is doing the trick! Absolutely no heat from the heater box on a test drive when the temp knob is turned all the way down. Now that I think about it, I never opened the valve up, so it’s possible some air is trapped in there from when I replaced it. I’ll post back if there are any problems, but for now I think this is the solution. Thanks for the help!
