Fuel pump flow problem
Posted By Jim Yergin 3 Years Ago
Jim Yergin
Posted 3 Years Ago
Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)
Posts: 22, Visits: 53.5K
I have a 1956 Thunderbird with a 312 and manual transmission. I have a problem with the mechanical fuel pump in that when climbing a steep hill the car runs out of gas unless I turn on the auxiliary electric fuel pump. To try and fix the problem I rebuilt an original AC mechanical fuel pump with a kit from Then And Now. Unfortunately that did not fix the problem. So I pressure tested and flow tested the rebuilt pump. It passed the pressure test but on the flow test it only produced a 1/2 pint of fuel in 30 seconds rather than the 1 pint called for in the shop manual.
To make sure that the problem was not in the input line from the tank, I bypassed the mechanical pump and ran the input line directly to the carb so that I could run the car with just the electric pump. I then ran an independent input line from a free standing gas can to the mechanical pump and ran an output line from the mechanical pump to a container. I started the car but the mechanical pump still only produced 1/2 pint in 30 seconds.
Does anyone have any suggestions as to why the mechanical pump is not producing an adequate flow of fuel? Did I miss something in the rebuild?
Thanks.
Jim Yergin
stbart
Posted 3 Years Ago
Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)Supercharged (146 reputation)
Posts: 50, Visits: 4.8K
when you rebuilt the fuel pump did you replace the check valves also or just the diaphragm? I was having the same problem but after rebuilding the fuel pump I have never had the problem since.
peeeot
Posted 3 Years Ago
Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)Supercharged (780 reputation)
Posts: 357, Visits: 25.5K
Is this a problem that has developed, or was it always a problem with this pump?
If there are no restrictions and the check valves are seating properly, the only other reason I can think of for insufficient volume would be insufficient pump stroke. Maybe the pump eccentric is worn out?
Jim Yergin
Posted 3 Years Ago
Thanks for the responses.
This has been a problem from the start with this pump. It was also a problem with the previous pump which is why I installed this rebuilt pump.
Jim Yergin
Richard
Posted 3 Years Ago
Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)Supercharged (902 reputation)
Posts: 399, Visits: 81.0K
Can you measure the eccentric for wear.
Jim Yergin
Posted 3 Years Ago
I think I would have to pull the front cover of the engine to get to it. I would rather not have to do that if possible, but good suggestion. My engine only has 60,000 original miles on it and when I refreshed it 10,000 miles ago I did not notice any wear on that part.
Jim Yergin
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
Is your pump an off-shore aftermarket pump? There have many complaints regarding off-shore (China) fuel pumps. For that reason, Casco is paying $50 for rebuildable pumps made in USA and Mexico.
Joe-JDC
Posted 3 Years Ago
Last Active: 4 hours ago
Posts: 772, Visits: 22.6K
Sounds like your tank pickup sock is plugged up a bit.   Hard for a vacuum pump to keep up, but the electric pump overpowers the clog.  Joe-JDC
Jim Yergin
Posted 3 Years Ago
The pump is an original AC pump that I rebuilt.
I don't think it can be a problem in the tank because it had the same low flow problem when drawing gas from an independent gas can.
Jim Yergin
Posted 3 Years Ago
Jim, did you operated the pump by hand before installing it. I do that with every pump I’ve ever put in. A bad one sounds different than a good one. Also can you look in the hole with a mirror and a light to see the eccentric?
