camshaft
Posted By darrell 3 Years Ago
darrell
Posted 3 Years Ago
Last Active: 5 Months Ago
Posts: 455, Visits: 22.2K
a friend has a 312 with a camshaft he hasent seen before.he doesnt think its a ford.this is whats stamped on it.88300 below that is N424 and below that is 900 on the centre of the first zero is a w..anyone have any ideas.
Posted 3 Years Ago
The numbers do not mean anything to me.  A quick measurement of the intake and exhaust lobe lifts with a micrometer or dial caliper will at least be a starting point if the camshaft is sitting outside of the engine.  Easy enough the reverse the advertised duration, the 0.050” duration, and the lobe centerline using either a cam doctor or just putting the camshaft in a block and doing an actual measurement for those values.
Maybe someone else may have a clue as to those identifying numbers.
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
Darrell, considering your friend does not know what he has, I have to conclude that he didn't buy it but discovered it upon removing it from his engine. Trying to identify it by those numbers is most likely equivalent to "finding a needle in a haystack." Maybe the person who sold the car/engine to him knows.
darrell
Posted 3 Years Ago
right its an engine he just got. it had 2x4 on it but its not an orginal E motor.
