B-rad
Visits: 1.5K
Just got registered. I've been on other forums and was told to get on here cuz my car is kinda special. It's a 54 Lincoln Capri with 68k. Sat since 1968 in a hay barn in AZ. Car has ac, I think it's after market from the factory. The evaporator is in the trunk and two clear plastic tubes send the fold sir over the rear seat into the passenger compartment. The compressor looks like an old Harley engine, 2 cylinders. I pulled the engine and transmission out together and am attempting to remove the transmission but running into problems. I understand that it has a hydramatic gm tranny with no torque converter. Someone on another forum said I need to remove 20 cap screws from the flywheel using where the starter was. Anybody know for sure how to get it off?
Deyomatic
Last Active: 4 hours ago
Visits: 2.3K
Any photos? Is this modified? It seems odd that Lincoln would have used a GM tranny but that Hydro was stout.
B-rad
Visits: 1.5K
Last Active: 2 Weeks Ago
Posts: 1.9K,
Visits: 194.9K
Welcome to the forum. I’ve got a soft spot for those, my Dad had a 54 Capri he bought in 55, and had until 61. 4 doors, no waiting, same exterior color as yours. Dark green leather interior.
Lincoln used the GM hydro-matic until they built their own (or bought out) heavy duty version of the Fordo in 55 or so, IIRC Turbo Drive in the Lincoln’s.
You might add your location. Might get lucky and someone is close.
Great ride.
B-rad
Visits: 1.5K
Lou
Last Active: 5 hours ago
Visits: 8.3K
Your AC is factory stock including the compressor and the tubes running up into the headliner..It's really rare to find a complete AC set up of that vintage.
B-rad
Visits: 1.5K
Lou, the tubes don't run into the headliner, just out of the rear deck and into the passenger compartment. I have seen what you're talking about. They look like a newer SUV or van where there are chrome vents coming out of the headliner. This wasn't set up that way, that's why I believe it is an after market. Someone told me they believe they did the after market at the factory, pulled the car out of line and installed it. I really don't know for sure. I wonder if anyone knows how to test the components to see if they will work. It would be neat to see that compressor hooked up and working again
Dobie
Visits: 22.0K
Novi Equipment Co. out of Novi, Mi. was the major supplier of automotive AC in the early to mid 50s. The systems were installed at the factory as well as by dealers and the aftermarket. The compressor had no clutch, meaning it operated any time the engine was running. You turned the system "off" by operating a valve that bypassed the refrigerant around the evaporator, eliminating the cooling effect. If you can rotate the compressor by hand it may just work, especially if there is still refrigerant in the system. The compressor may be rebuildable since it was just an adaptation of a stationary refrigeration unit. If not you can adapt a modern automotive compressor like a Sanden SD508. The system holds about 10 lbs. of refrigerant, originally using R12 which has been outlawed by the EPA for close to 30 years now. I lived in Dallas in the 50s and I remember these systems would flat freeze you out of the car in short order, even on the hottest days. Here's a link to a thread about them on the HAMB: https://www.jalopyjournal.com/forum/threads/novi-equipment-company-traditional-auto-air-conditioning.410927/
1930artdeco
Visits: 5.1K
Welcome, and nice car you got. There is a thread over on the Ford Barn-late V-8 talking about your exact transmission issue (sorry, just realized that it was you posting the same question over there). As for your AC system, I looked at another late 50's Lincoln and it had the exact same system blow in from the trunk through clear plastic pipes into the pass compartment. Not sure if you can have the compressor be rebuilt or not. I was told no on a 75 compressor but I am no expert.
Mike
Posts: 3.3K,
Visits: 238.8K
Brad: welcome to the site.. there are one or two people on this site that are quite familiar with those engines etc.. I believe that one of them bought a large collection of parts including some higher performance stuff recently.. Hopefully you are able to get the car into decent shape without spending a fortune, unless that doesn't bother you?. 54 Capri 4 Dr.s were listed in the OId Car Report Price guide as of 2017- at just under $15000 in # 2 condition.. There was also an Ad in that issue for parts out of Florida; www.lincolnoldparts.com or Herb @ 727-445-1091
