Last Active: 8 hours ago
Visits: 41.5K
Can someone provide me with the part # for the Y block dampener redi sleeve? Searched our site with no luck. Thanks
SE Wis
Visits: 1.8K
Dave, what is your specific application? I can lookup the part number in one of my Tbird catalogs, but the Tbird dampener is not the same as those equipped on full-size and trucks.
If you send your dampener out for rebuild, they will install the redi sleeve.
Although the groove on mine was very shallow and probably could have been polished out, Damper Dudes installed the sleeve.
Visits: 1.8K
hillsresto.com part # 6312-A, $17.95.
Visits: 41.5K
56 car with a 57 312 engine
SE Wis
Visits: 41.5K
Thanks for that part#. Should help me
SE Wis
Visits: 1.8K
You're welcome, Dave.
If you call Hill's, they should be able to tell you if it's correct for your application. I just don't know if it's one-size-fits-all.
Last Active: 7 Months Ago
Visits: 21.9K
Go to Rockauto.com enter Ford then 1964 then F 100 then 292 then engine then look for damper repair sleeve. $3.?? Low $7.?? High. 3 to choose from.
Duane
Visits: 1.8K
Good tip! I usually check RockAuto for common items, but I considered the dampener sleeve a specialty item.
Visits: 41.5K
Wow! Never thought that Rock Auto would have it. Thanks
SE Wis
Last Active: 5 Months Ago
Visits: 22.2K
hard to beat rock on a lot of things.not everything is a good price or quality but my favourite stop.
