Visits: 696
Thanks Mike that's what I was looking for. Any carburetor recommendations would be greatly appreciated.
Posts: 1.9K,
Visits: 195.0K
I’m not sure this is the right one, but it gives you an idea. Someone else would know. While I’ve run both the 1406 Eddy’s and the 600 Holleys, I’d be looking at some of the more efficient smaller carbs today. Again, someone with personal experience should address that. https://www.summitracing.com/parts/trd-2064
Visits: 696
Can anyone point me to a adapter plate?
Visits: 696
I have a ECB-9425-B so I will need a adapter. I'm probably going aftermarket with pertronics
Visits: 498.2K
If the 4000 is rebuilt correctly, it's just as good as a later Holley in my opinion. I run a 4000 on my 56 Bird, and it runs very good. Do have a later distributor and the Holley is modified for the later distributor.
Just don't have the 4000 rebuilt by the guy down the street.
Visits: 2.6K
I used to have a '55 Fairlane with a 272 and went from the 2 bbl to the 9425-A (small base 4 bbl) intake....I am guessing that is what you have. Aside from the physical work the hardest part was finding the carburetor gasket for the 9425-A manifold. I didn't know if an adapter existed so I bought a 1" aluminum carburetor spacer and used the small carb gasket as template, drilled out holes that matched the holes in the small gasket and countersunk the holes and match ported the holes in the intake to the holes in the spacer. Then I just bolted that to the intake with Allen bolts...then it was just a matter of bolting on an Edelbrock 500 with a manual choke...Whatever model number that is. It ran great. While I only vaguely remember it- I also swapped distributors at the same time. I had a bad Pertronix Ignitor II that only lasted a couple of months so I switched back to the points and condenser.
For a reliable cruiser, you want a new aftermarket carb and electronic distributor. You will also need a carburetor adapter or do an intake swap, in order to mount a new carburetor.
Visits: 696
I have a stock 272 with a stock holly 4000 4 bbl and a loadamatic distributor. Carb leaks and I need to replace it. Should I buy a rebuilt 4000 and stay with the stock setup or get a aftermarket carburetor and electronic distributor? I want it to be a cruiser and reliable. Did a search but couldn't get a concise answer.
