Visits: 3.9K
12/26/2021
Wanted: 14 tooth distributor gear Ford P/N FAE-12390-A for an original '57 y-block ball bearing breaker plate distributor. Existing distributor in generally good shape; gear is somewhat rust-pitted and needs to be replaced. I've looked all over "the web" with no success so far.
I'm not on here all the time - expect reply delays of a few days.
Thanks, JLB - 1955 Crown Vic steeltop
To: Duluth MN 55810 - shipping details in private message when I reply to any offers - retired & on "budget", reasonably priced offers only, please.
Last Active: 1 hour ago
Visits: 498.2K
In case you cannot get a used one, this vendor says they have new ones
distributorgears.com
Visits: 3.9K
Bump
Thanks for the vendor info. Unfortunately, it needs to be my last resort due to cost at $79.00 + S&H.
Ted, would you happen to have a "decent" one available from your "removal" batch as taken-off to make oil pump drives as described recently? Anyone else?
As said: The aforementioned vendor's cost is more than I paid for the distributor; & trying to build a decent distributor within my budget means.
Thanks, JLB
Send me your snail mail shipping address via email and I’ll stick a 14T distributor gear in the mail. My email address can be located at EatonBalancing – Precision Engine Balancing .
Visits: 3.9K
Ted, Thanks very much for the offer; I've sent info. to you at your email: " eatonbalancing@yahoo.com". Regards, JLB
Visits: 3.9K
Folks: Ted sent me a good gear. Thanks very much Ted! Thanks again, JLB
Visits: 1.5K
Ted, do you have a drive gear for a 54 Lincoln Capri 317 y block?
Visits: 1.5K
Ted, do you have a drive gear for a 54 Lincoln Capri 317 y block? I need 15 tooth gear from 417 lyb dizzy
