Temp Gauge Sender Location
Posted By Deyomatic 4 Years Ago
Posted 4 Years Ago
Posts: 1.8K, Visits: 306.3K
Along with the CASCO PUMP and PARAGON SPACER (not needed w CASCO PUMP) is another little detail. This casting defect will affect both the BIRD and PASS CAR.
https://img1.wsimg.com/blobby/go/38978bd3-5ae7-4960-b749-ae5d7a9bfeb1/downloads/Potential%20obstruction%20to%20coolant%20flow%20-%20TCC%20-%20.pdf?ver=1626635531044
Posted 4 Years Ago
Posts: 3.6K, Visits: 497.7K
The sedans cannot use the CASCO pump and no spacer on a sedan.
Deyomatic
Posted 4 Years Ago
Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)
Posts: 292, Visits: 2.3K
DryLakes,
Can you post a photo of the bypass modification that you speak of?  Does each side get a 3/8" plug?
Do you know the diameter of the pulley?  Summit probably tells me.  I just have no clue what has been done to this already.
Thanks again.
Posted 4 Years Ago
There is more that just adding the plug with the 1/8 inch hole.  The thermostat must be modified too.
I found this out when I did the plug thing to my 56 TBird. With the plug in, when the car starts to warm up it gets really hot - nearly pegged the gauge  - got me very nervous - while the temp went down when the stat opened, it is not a good feeling when the gauge is pegged.  Not wanting to pull the stat, I took the plug out.
DryLakesRacer (9/30/2021)
In the bypass hose, the intake to the water pump. Add a plug… 3/8” pipe works good with a 1/8” hole. Forces more water through the rad instead of recirculating.
Deyomatic
Posted 4 Years Ago
Thanks DryLakes,
I ordered what I think is the right smaller pulley.  Mine is also around 7.5"...new one should be 5.82" according to CJ Ponyparts, or whatever it is.
I had a '55 Fairlane with a 272 in Phoenix valley almost 20 years ago and never had any cooling issues.  That's why I was so surprised now.  I'll keep an eye on it and play around.
When you say you block off that bypass between the pump and the thermostat housing, do you just put a piece of all thread or something in there and clamp it down?
Thanks again.
D
Posted 4 Years Ago
https://img1.wsimg.com/blobby/...
Paul,
I think most realize this.
What is being discussed in the VOLUTE OPENING in the FRONT TIMING COVER. Did you read the TECH ARTICLE?
Lord Gaga
Posted 4 Years Ago
Posts: 464, Visits: 183.3K
Restricting the bypass hose puts extra pressure on the heater core and its hoses and is of no real benefit. A word to the wise...Been there, tried that.
"FREE SAMPLE"
Posted 4 Years Ago
TRUE.
The by-pass was engineered into the equation for a reason.
Deyomatic
Posted 4 Years Ago
I got my new water pump pulley today and it LOOKS like it will work.  I will post back.  I figure that pulley and a 180* thermostat will get me in better shape.
Posted 4 Years Ago
Are you getting a hi-flow thermostat. As once stated a Mopar V8 is the same diameter.
