Posts: 2.0K,
Visits: 131.1K
fellas, Stan with FPA already got back with me and he says he has nothing that will fit.
Visits: 3.6K
Posts: 1.9K,
Visits: 195.0K
This info is 10 years old, so something might have changed. I bought the flanges for my roadster from Stan’s Headers in Auburn. At that time he produced them, and I believe he also built the FPA bird headers to their design. They happen to be located between me and my mothers house, so I drive by them a couple times a week. 2 different “Stan’s” http://www.stans-headers.com/
Posts: 2.0K,
Visits: 131.1K
Thanks Joe, from yourself and the two builders you mentioned it surely sounds like I am on the right track here. I will contact Stand and see what he has. I did re-read Ted's article on the dyno results of a variety of headers, but I find that the typical 4 into 1 header for the Y Block and the 55/56 Ford passenger car application do not include many options. Thanks again, Dan
Visits: 23.0K
Speedway motors has header flanges available for the Y Block for ~$49. I have two sets, and found them to be smallish for my requirements, but was able to open up the port sizes quite easily. They will work well with either a 1 1/2" or 1 5/8" pipe. I needed a 1 3/4" primary for my dyno headers. You might try Stan at FPA for a set of headers. They are not cheap, but they do make good horsepower and torque for the Thunderbird.
BTW, Jon Kaase used a SBC set of headers that he modified for his EMC Y block build, and if my memory is correct, Ted's dyno headers started life as SBC headers. Joe-JDC
Posts: 2.0K,
Visits: 131.1K
Does anyone have any photos or suggestions on modifying SBC headers by cutting off the XXXX flange, separating the two middle tubes, and welding up a Y Block header flange? Particularly interested in what anyone has done for a 55/56 Ford passenger car with standard transmission. I would be in the market for a set of Jardeen's but that may be a rare find right now. Any leads on quality flanges?
