312 HD Connecting Rods Available?
Posted By Daniel Jessup 5 Years Ago
Rated 1 star based on 1 vote.
Daniel Jessup
Posted 5 Years Ago
Last Active: 8 hours ago
Posts: 2.0K, Visits: 131.1K
Last month when I contacted John Mummert and purchased an adjustable timing set, he stated that he could no longer get the 312 HD Connecting Rods. While I did not get into the details of what has taken place with a manufacturer, I thought I would throw the question out to all of you - is there any company that offers H-beam connecting rods for the 312 off the shelf?
Daniel Jessup
Lancaster, California
suede57ford
Posted 5 Years Ago
Posts: 216, Visits: 106.5K
I'm also in the market for upgraded 312 style rods as I have broke so many 312 and the truck style rods and ruined several motors so I never want to use the stock type rods in anything I have anymore. I'm sure some of my rod failures were heavy pistons.
I may look at offset grinding the crank and using a set of eagle 6.125's in one i'm about to do..  I always plan to have custom pistons made so the the eagle rod might be the best for me.
Pat Fleischman
Daniel Jessup
Posted 5 Years Ago
Pat, with the cost of getting a set of rods re-worked, adding the ARP hardware, etc, it would be better to just buy a set off the shelf like the Eagle set you mention. In the end you save money I think and end up with a much stronger rod. Just for kicks I found these within 5 minutes - have you ever gone with that size rod journal?
https://www.ebay.com/itm/174128458536?hash=item288add6b28:g:WSgAAOSwZBheneZJ
Daniel Jessup
Posted 5 Years Ago
Posts: 7.5K, Visits: 205.9K
Daniel Jessup (8/6/2021)
I run both the 2.000" & 2.100" journals on the Ford Y cranks without issue. When going the 2.000" route I will target for a 1.810" journal width and then narrow the rods accordingly for 0.020" side clearance. The narrower rod bearings are available as an off the shelf item so that part of the process becomes relatively easy.
peglegrice
Posted 5 Years Ago
Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)
Posts: 10, Visits: 17
Danny, When John built my engine ( 16-18 ) years ago he went to the 1.88 rod journals, Still has the original bearings after any quarter mile runs and 13,000 street miles. Idles at 65 # cold and 30 # hot with 30 wt oil. Runs close to 70# at 2000 RPM cruise.
John Mummert
Posted 5 Years Ago
Posts: 918, Visits: 7.5K
We do make a 312 length H- beam rod that take 2.0" buick bearing, stock big end width, no need to widen rod throw and set up for .912" pin.  We mainly use then for making 292 cranks into 312 stroke, We do have short compression ht. pistons for stroking 312 cranks as well.  Early versions of this rod were I- beam and made by the same vendor that made our heavy duty replacement rods (no longer available).
 We just got the new H beams in stock.
http://ford-y-block.com
