Torque for rocker shaft caps?
Posted By JimNNN 4 Years Ago
JimNNN
Posted 4 Years Ago
Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)
Posts: 17, Visits: 9.2K
Hi. For some reason, I didn't see a torque spec for the rocker shaft cap bolts in the shop manual for my '54 EBU 239. Does anyone know what that should be?
The lock nuts for the rocker adjusters are supposed to tightened to 30-35 ft. lb.s I think. Thanks - Jim
Posted 4 Years Ago
Duh!   Maybe I'm having another dull moment?..  Am  I the only one that does not understand your question?.. Cap bolts?
JimNNN
Posted 4 Years Ago
I'm probably not using the right terminology. I don't have the shop manual with me at the moment.
The rocker shaft is held in place by what I'm calling caps, but they're brackets really. Two bolts each, except for the the locations that have studs (for the valve cover nuts.)
I need the torque spec for these bolts that fasten the rocker shaft to the head...if it exists. I didn't see a spec in the shop manual, but I may have missed it. Thanks.
Posted 4 Years Ago
Posts: 1.8K, Visits: 306.3K
In the TORQUE LIMITS (1954 FORD WSM) chart, look @ Rocker Shaft to Cylinder Head.
I think that is what you want.
Tedster
Posted 4 Years Ago
Posts: 513, Visits: 153.3K
What size are the bolts? Shank size. Are they the same as in later Ys? For those, it's listed as 12 to 15 ft/lbs.
Posted 4 Years Ago
The‘57 Service Manual specifies 12-15 Foot-Pounds for the rocker arm support bolts (rocker shaft to cylinder head).
JimNNN
Posted 4 Years Ago
KULTULZ (7/23/2021)
Thanks KULTULZ, Tedster and Ted. I figured I missed the info in the manual. You've been a big help.
Tedster
Posted 4 Years Ago
It might take a few heat cycles and cool downs for the bolts to stabilize, so re-torque or torque check them. 15 foot pounds is not a lot. If I'm thinking of the geometry correctly the valve lash clearance might be affected slightly until they settle down.
Posted 4 Years Ago
Posts: 3.6K, Visits: 497.7K
I was helping a friend put together a 312 and that question came up.  Found it in the 56 shop manual, it was as Ted had noted.
JimNNN
Posted 4 Years Ago
Yes, I should've mentioned for the benefit of others that I found the specification in the '54 manual (addendum) where KULTULZ said, and the proper torque was 12-15 foot pounds like the other years' applications. I was looking for the number in the text because the rocker lock nut torque was stated there. It was in the spec section in the torque limit table, where I should've looked first.
