55-57 Tbird Front Engne Mount
Posted By paul2748 4 Years Ago
Posted 4 Years Ago
Last Active: 6 hours ago
Posts: 3.6K, Visits: 497.6K
very good condition, all it needs is paint.  Located in New Jersey.   80.00 plus shipping  PM mehttp://forums.y-blocksforever.com/uploads/images/d779d13c-f966-4865-9823-5732.jpghttp://forums.y-blocksforever.com/uploads/images/497827f7-2077-438d-a6c3-f588.jpg
Posted 4 Years Ago
Posts: 1.7K, Visits: 306.2K
Does it have any STAMPING ID NOS.?
Posted 4 Years Ago
No - It came out of my 56 Bird if your questioning whether it's the correct one.
KULTULZ (6/25/2021)
Posted 4 Years Ago
Not questioning, just curious,
Posted 4 Years Ago
Some FoMoCo parts have original parts markings, but some do not.  I've never seen any FoMoCo ID markings on this particular 'Bird part.
Related to Kultulz's inquiry, I've seen several '55-'57 'Bird timing chain cover front engine mounts that have been scored by the 'Bird's crankshaft vibration damper 'donut' moving so far back as to permit contact with it when the engine is running.  This 'donut' contact can emit a high pitched, intermittent chirping noise when the engine is idling in the early stages of the 'donut' having moved out of place on the damper body.  Paul's support mount is in pristine, unmarked by the 'donut', condition!
I hope this helps someone!   Smile
carl
Posted 4 Years Ago
Posts: 1.2K, Visits: 20.6K
Paul i have a identical one that was on a truck 292 y block so apparently they were used for birds and truck   Carl
Posted 4 Years Ago
Not having seen a  truck front mount, I always wondered if they were the same
carl (6/29/2021)
Posted 4 Years Ago
Posts: 1.8K, Visits: 194.2K
My memory isn’t what it used to be, but I’m pretty sure the truck and bird mounts, while similar, are different. The bird mount requires the different dampener, and the water pump spacer. I don’t think those are used on the trucks.
Posted 4 Years Ago
The bracket itself is used in both the BIRD and F-SERIES - PN B6C 6028-A
That is why I asked if there were any ID STAMPINGS.
carl
Posted 4 Years Ago
i would post a picture of it but not sure how to do that  Carl
