skyhunter
Visits: 354
So I have a PCV set up on my 292. The PCV valve is on the rear of the valley pan and feeds back into the intake. The fresh air goes from the air cleaner base to the oil fill cap but it is the open element type with perforations under it and a hose connector.
I am getting oil up under my hood near the hinge from it. Should I have a closed cap with just the hose attachment.
Should the other valve cover be vented some how? They are the finned Spotlite Customs finned covers.
What did I done do wrong?
Thanks.
1959 Edsel Ranger, 1916 Ford "speedster" "I may not be a rich man, but I can give you a million dollars' worth of bad publicity."
Posts: 1.8K,
Visits: 306.3K
Any chance of photo(s) showing the install?
2721955meteor
Visits: 190.0K
the breather at the filler tube should not have a vacuum source. with a pcv creating a vacuum in the valley restricts oil return to the sump. in my case I have no spill tubes on rocker shafts so lots of oil I found I had to remove the pcv valve, routed the hose into th air cleaner carb side of air cleaner. my take is Ys wher never intended to have blow by taken into the intake, or fitting in carb base. I think if the spill tubes are left in the rockers you could get away. my opinion is lots of oil too the rockers as well as valve train makes for longer life esp camshaft and valve train
Posts: 1.8K,
Visits: 306.3K
Yes, closed filler cap with fresh air intake tube to ACL.
Not needed.
The fresh air source will not affect the internal baffling and ventilation of the crankcase if there is no blow-by..
Would still like to see photo(s) of the install. Most are not done correctly (IMO).
2721955meteor
Visits: 190.0K
KULTULZ (6/20/2021)
Not needed.
never saw a engine gas or diesel that has no blow by .the cap over the oil fill tub is a breather and should be serviced at oil changes .the road draft setup worked well, tho original y set up was ok but prone to external leaks as the cover being over tined stretched the poor ly designed.
Posts: 1.8K,
Visits: 306.3K
never saw a engine gas or diesel that has no blow by .the cap over the oil fill tub is a breather and should be serviced at oil changes .the road draft setup worked well, tho original y set up was ok but prone to external leaks as the cover being over tined stretched the poor ly designed. | | |
The OP is describing a CLOSED PCV SYSTEM whereas fresh air for crankcase ventilation is drawn through the carb air cleaner instead of a vented/filtered oil fill cap (OPEN PCV SYSTEM). It first appeared 1963/64. Surely you have seen such a system. Amount of blow-by vented is as a result of engine condition and/or crankcase ventilation system integrity.
skyhunter
Visits: 354
I will take pictures when I get it back from Intercity Transportation.
2721955meteor
Visits: 190.0K
yes I have seen the system you note, but never one a y block. fes where equipped so. Hear in canada ys wher no longer in cars. trucks only and had road draft from the rear of the valley, with filler caps as air intake. also the ys in trucks wher notorious for loosing oil pressure on down hill or heavy braking, due to the oilpan.with no bafels would be interested to see a photo of y with positive crank ventilation as Oem installation. have witnessed a sb ford with valve cover filler taped off and total bottom end failure do to oil not returning to base fast enough due to vacuum build up in valve covers. ENOUGH SEAD FROM ME AND WE CAN AGREE TO DISAGREE
Posts: 1.8K,
Visits: 306.3K
... hmm ... (must have forgotten the words to the song) ... anyway ... OP Posted - So I have a PCV set up on my 292. The PCV valve is on the rear of the valley pan and feeds back into the intake. The fresh air goes from the air cleaner base to the oil fill cap but it is the open element type with perforations under it and a hose connector.
He doesn't mention year/model. 1961/ came through with PCV SYSTEM.
I was a$$-u-me(ing) that he was referring to a retrofit.
There is no argument, either it is or isn't ... (much akin to my sex life).
patm
Last Active: 5 Months Ago
Visits: 17.6K
Is the PCV installed correctly, facing the correct way, vacuum input on the correct end of the valve?
Pat in AZ
