Isky Model: 301444 Cam
Posted By 312YBlock 5 Years Ago
Daniel Jessup
Posted 5 Years Ago
Posts: 2.0K, Visits: 131.1K
this is what you need...http://forums.y-blocksforever.com/uploads/images/18cb3c98-e795-49b4-9ed1-c833.jpg
Daniel Jessup
Lancaster, California
312YBlock
Posted 5 Years Ago
Posts: 217, Visits: 57.3K
Thanks guys, but I may have found what I’m looking for from Summit Racing. I have to do a little more research.
Rocker arm screws
PRW Industries 1205230 - PRW Rocker Arm Adjuster Screw Kits
1955 312 T-Bird Warwick, NY
Posted 5 Years Ago
The jam nut adjuster is one of the two methods of holding the adjustment.  This requires a wrench and screwdriver (or allen wrench for aftermarket rocker arms or screws).  The other is with interference fit adjuster screws, which only require a socket or wrench.
The interference adjuster eventually becomes loose and the jam nut adjuster is best.  It does take some practice.
Posted 5 Years Ago
Last Active: 8 days ago
I concur with Charlie. Mummert has both types of adjusters, but those/w nuts are more expensive. I think Crane has/had the self-locking adjusters (no nuts) that got good reviews.
Posted 5 Years Ago
You might try .019-.022 and leave feeler gauge in place while tightening lock nut. If you can remove the feeler gauge, you should be in the ballpark. I don't mean to be a wise guy, but you do realize you have to use the screwdriver to keep the adjuster from turning while you tighten the nut? Valve adjustments are pretty much a thing from the past and don't apply to most modern cars, foreign makes possibly excepted.Not everyone has done it.I grew up around motorcycles that used screw adjusters and still prefer them to shims, even though they have to be checked more often.
DANIEL TINDER
Posted 5 Years Ago
Posts: 1.8K, Visits: 154.5K
Daniel Jessup (4/23/2021)
Neat tool.  Eliminates the need for feeler gauges (except initially), at least for the average motorist not requiring ‘racing caliber’ lash precision.  Indicator dial works on the ‘screw micrometer’ principle.
6 VOLTS/POS. GRD. NW INDIANA
312YBlock
Posted 5 Years Ago
Using all your strength trying to hold the screw driver left while turning the box wrench in the opposite direction is a contest I assume you have not yet experienced.
Posted 5 Years Ago
Helps to be lefthanded.
312YBlock
Posted 5 Years Ago
Believe it or not I am left handed 😊; I finished the job and the engine runs great it’s just such a hassle. In the video I saw the guy did both banks in under 10 minutes, took me 3 hours. I love to find out what he has for adjusting screws.
312YBlock
Posted 5 Years Ago
