56 Montclair w/312 automatic shaking when put in gear
Posted By TheWitz 5 Years Ago
TheWitz
Posted 5 Years Ago
Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)
Posts: 16, Visits: 7.7K
This car was running smoothly but it lacked power. We found low compression on some cyls. The engine was pulled and a local shop rebuild it. The engine has much better power now, but the issue is this: At idle, the engine is running smoothly, but shift into drive and the car starts shaking. It wasn't shaking before the engine was removed. The transmission and torque converter were not removed when the engine was pulled. When stepping on the gas, applying power, the shaking is not noticeable. It's just at idle that it is really noticeable. A whole lot of shakin' goin' on. The transmission is the 3 speed automatic that starts out in 2nd and has no overdrive.
Any thoughts on what could be causing the shaking?
We're trying to figure out if it's the engine, once it is under a load when shifting into drive, that needs an adjustment, or is it the transmission or torque converter.
Thanks.
Cliff
Posted 5 Years Ago
Last Active: 7 hours ago
Posts: 892, Visits: 13.7K
Check valve adjustment, dial in the carb.
Posted 5 Years Ago
Last Active: 1 hour ago
Posts: 4.6K, Visits: 38.8K
Double check the firing order.
Posted 5 Years Ago
Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)
Posts: 1.3K, Visits: 1.9K
Was it rebuilt to OEM specs?
TheWitz
Posted 5 Years Ago
As far as I know, the engine was rebuilt to specs, however the pistons are now 30 thousandths oversized. I pointed the shop that did the rebuild to website ford-y-blocks.com where they ordered what they needed to do the work.
As far as firing order, I'll check, but the engine is running strong at idle and on acceleration. I would think if the firing order were off, it would be shaking all the time and lack power.
Posted 5 Years Ago
Idle speed to low when in  gear?..  A vacuum leak?
TheWitz
Posted 5 Years Ago
Idle speed was on the high side when it was first put in gear. Lowered the idle a little with no change to the shaking.
As far as vacuum leaks, that is a possibility I will look into. Thanks.
One other item as it pertains to vacuum. The power brake booster was not removed when the engine was pulled. The brake line was disconnected and the four bolts holding the brake booster were removed and the unit was held to the fender well so it was out of the way. Now that it's all back together, the brake pedal is hard and there is no power braking. Vacuum was present at the booster and past the check valve on the booster. I believe there's a diaphragm inside the booster. If it's damaged that could explain the hard pedal and a vacuum leak. I'll try capping that line as a test to see if the shaking goes away when I shift into gear..
Posted 5 Years Ago
Last Active: 13 hours ago
Posts: 7.5K, Visits: 205.9K
Assuming the engine is in good condition and there are no vacuum leaks, this sounds like a tuning issue.  I’ll suggest revisiting the ignition timing and idle fuel mixture settings.  If necessary, block off all the external vacuum sources to eliminate that as the source of the rough idle.  This could be as simple as being too lean when putting the transmission into gear.
junkyardjeff
Posted 5 Years Ago
Posts: 813, Visits: 3.4K
Make sure its running on all 8 and look for vacumn leaks.
Posted 5 Years Ago
Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)
Posts: 3.7K, Visits: 32.8K
What Carburetor are You using?
