I bought this manifold about 5 years ago right after I started on the dual quads I ended up using. If I went to the single I would use it. You can see the casting has a ECZ-9425-B and not the 8425. There are holes for a choke heat tube but no other casting numbers or casting company or logo. It came as a complete kit. Bolts, washers, gaskets. I don’t remember where I bought it but it was on-line and I had to sign for it on receiving it. I thought it may have been a knock off of a Blue Thunder or one they made with their logo not cast.
Posts: 1.4K,
Visits: 179.6K
1/8Cavman. Welcome to the site! Early '57 production FoMoCo y-blocks (Ford & Mercury) using the B single quad intake manifold did not have the firing order displayed! This was true for both passenger car and 'Bird applications. My recollection is that it was in February of the '57 model year that the firing order was first displayed on the 312 engine single quad application intake manifold casting. This information was previously covered in an earlier Y-Blocks Forever Forum entry and, as I recall, in the Classic Thunderbird Club International Restoration Manual authored by Gil Baumgartner. The information pertaining to casting date codes, no choke heat tubes for truck applications, and the B code intakes being the best for performance of a y-block factory single four barrel intake are both correct and reliable. Hope this helps!
Last Active: 59 minutes ago
Visits: 323.2K
I compared my manifolds, the ports are the same, the throttle bore holes are the same, the depth from the carb flange to the plenum floor are the same. Ted, where did you come up with that EDB-9425-F manifold????? Is it for sale?
Posts: 7.5K,
Visits: 205.8K
Visits: 1.8K
Woops! I posted this in the wrong place. If you are going to port-match your manifold to your heads, you should also consider opening up the plenum to two ovals. you can find photos on yblockguy.com and eatonbalancing.com.
1/8cavman
Visits: 40.2K
Both of these manifolds have the ECZ 9425 B casting. They are the 57 and later Holley 4150 bolt pattern. I know what the 55 and 56 intake manifolds look like. Hoosier Hurricane you are probably correct. I didn't realize 4 barrel manifolds were used in HD trucks. I am opening up and smoothing the runners a little, trying to match them to the heads which I did years ago. Nothing radical. Aluminum parts (heads, covers, manifolds) would be great but at this time too much money. Hope the price of fuel doesn't go nuts. Thanks guys for your replies.
Visits: 323.2K
Here's ;my take on the two manifolds. I have both types, though I never noticed. I believe the ones with no firing order are passenger car manifolds. The ones with the firing order are HD truck manifolds. The ones without the firing order have provisions for the automatic choke heat. The one with the firing order is not drilled for the choke heat tube. Passenger cars had automatic chokes, HD trucks had hand chokes. Tomorrow I'll put them side by side and see if there differences in port sizes and throat sizes. They may be different, they have to be different castings because of the cast firing order info on top. The cores for the inner parts may be the same for both types however.
Visits: 1.8K
The 57-up Holley 4150 base bolt pattern is 5.16 (5 3/16) side-to-side/5.625 (5 5/8) front to back.
Visits: 1.8K
1/8cavman, check your personal messages.
Visits: 1.8K
Do the letters ECG precede 9425B? I just looked at two manifolds. Both were the 57-style. One had the firing order on a runner, but the other did not. The carburetor bolt pattern is wider than the 55-56 4-barrel manifolds and will not accommodate pre-57 carburetors.They are the best Y-block OEM single-four-barrel-carburetor intake manifolds. If you replace 55-56 carburetor and intake with 57-up, you will also need a 57-up distributor with both mechanical and vacuum advance.
Posting photos will not only confirm the above, they will generate considerable interest if you want to sell them. If the price is right, they go pretty quickly. As you know, they are heavy, and that will be reflected in the shipping cost.
