Proper spin-on oil filter
Posted By Jack Groat 6 Years Ago
Lord Gaga
Posted 6 Years Ago
Last Active: 10 Months Ago
Posts: 470, Visits: 183.3K
Bob, I read a very intensive test of every oil filter that exists a while back and Fram emerged as one of the worst in terms of filtration. I was surprised to learn that there only a small number of filter manufacturers. https://www.b4usa.com/champion-laboratories-inc/
As I recall Purolator came across as one of the best.
(Things may have changed since I read the article, it seems that there is a lot of supplier swapping in the industry)
"FREE SAMPLE"
2721955meteor
Posted 6 Years Ago
Posts: 927, Visits: 190.0K
i do not agree with the negative  word re fram. i cut open every filter  i change,present frame filters are fine as are most other name brand filters.  when converting to spin on remember to trim the socket so you get max grip on a short nut that must be removed to inst adaptor. the concern for room is un founded.spin ons take less space than oem can.
the tin plat for conversion are to thin,i drill a couple of holes across from slotted oil feed to even the clapping of gasket also glue the gasket so it stays in place. in the end made my own adapter plat from alum. tubing. lots of lathe time  but works great
cokefirst
Posted 6 Years Ago
Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)
Posts: 168, Visits: 2.4K
I think the bad rep on Fram oil filters is the cheap insides.  There are videos on Youtube so I will not bore you with the details.  I am sure that the Fram filters meet the minimum requirements but once you see them taken apart, you can see why they may be cheaper.  I used to buy Champ or Champion filters.  They had the patent on the Sludge lock valve that allowed you not to lose oil pressure if the filter get's plugged.  Champions used to be reasonably priced but they are now at the upper end of the cost spectrum.
Posted 6 Years Ago
Posts: 3.8K, Visits: 33.3K
As far as sufficient room  for the full size PH8A type filters, the Shop Manual tells You to turn steering wheel to full right and this gives lots of room re steering Linkage.
Posted 6 Years Ago
I left Fram years ago before the internet because the race engine builders I knew told me there were better ones out there for slightly more. After the internet and especially You Tube where brand new ones were cut open to see what was actually inside, ie: filter media, glue, washers, spacers, valves, etc. it showed the poor products and craftsmenship of a Fram. Granted they had more than one model to choose from. Purolater, Wix, and NAPA always seemed at the top especially when the small items of the filter were pointed out and not just the media.
I too now cut everyone open with a filter cutter my son bought for his dirt car engines looking for debris. For my street I have found very little to nothing metallic which is fine. He uses Wix Racing filters we buy by the case off Amazon. I do miss the ease of the gripping surface of the Fram but won't go back.
Tedster
Posted 6 Years Ago
Posts: 513, Visits: 153.3K
Pg. 3 (They didn't waste any time in those days) of the Operator's Manual for my Truck is titled "The Value of Regular Maintenance"; after the initial pleasantries identifying me as someone who "understands value", due to my selection of a Ford, it outlines 11 of the Owner's Responsibilities, and the first 3 are
1. Check Oil Level Frequently
2. Use the Right Engine Oil
3. Use The Right Oil Filter
And sez:
"The engine oil filter is EVEN MORE IMPORTANT in preserving the internal condition of your engine."
That's almost certainly true, or at least the engineers would be in a better position to know. I'll take their word for it. Can't see any particular reason to save $.50 and use anything but the FL-1 or the WIX equivalent.
It isn't necessarily the filtering and obssessing over whether its 0.2 or 0.3 microns between brands, that we should be concerned with. One thing to note is how they are constructed, the actual location (and materials) of the bypass valve. Less expensive filters will allow dirty oil to drain back into the sump and circulate. Store replacement filters in their original box and also inspect the insides of the filter with a strong light for any manufacturing debris or defects prior to installation.
Posted 6 Years Ago
I, too, am not on the 'Fram is bad" band wagon.  My opinion is if they are so bad, then there would be numerous stories of engines being destroyed as a direct result of using Fram filters and those stories don't seem to exist.
When watching reviews, pay attention to how the reviewer explains things.  If the review is nothing more than filter A uses lower quality materials while filter B uses higher quality materials, therefore filter B is better, then they aren't telling you much.  That review can be disregarded.  You want a person who can explain why one is "better" than the other, not just declare that it is and with some context.  For instance, if one uses cheaper materials, which R&D determine is good for 4000 miles while another uses more expensive materials which is good for 5000 miles and you change oil every 3000 miles, what does it matter to you which is used?  Both will do the job. Make sure you understand why something differs in quality from another and determine for yourself if it will have any tangible impact for your use-case.  This goes for reviews of anything, not just oil filters.
Posted 6 Years Ago
I see that this subject is almost as controversial as "what oil I use in my engine"!  Fram filters are usually about the cheapest on the market & their filter seems to be the only one that gets bad publicity. Is it deserved? I don't know, but for a modest  price difference & for what it protects, I'll pay the difference. For my Y-Block, which is only a hobby car, so I'm not changing the filter every few months, I use the Motorcraft (Ford) FL-1A.  And when I read that Ted Eaton uses the Wix 51515 for his high perfomance engines, I'll recommend that one too.. Nuff said..
Posted 6 Years Ago
Paul,
         There was a "test" in hot Rod a few years back. I don't remember the date. They compared various oil filters one against the other. I don't remember all the results but the WIX filters were one of the best. Surprisingly the Frams were among the worst. I've used WIX ever since with good results.
slumlord444
Posted 6 Years Ago
Last Active: 5 Months Ago
Posts: 1.2K, Visits: 137.8K
My T Bird I always use Ford filters. My drivers I use what ever is cheap. Pick up a lot of filters at swap meets cheap. Also use Wal Mart genaric oil in my drivers. Change the oil and filter evry 3 or 4 thousand miles and no issues. Use Valovilen VR1 Racing oil in the T Bird. Change it once a year if it needs it or not. Retired mechanic budy always tells me that brand is not nearly as important as changint regularly.
